05133164001
05133164001
    WERA(维拉)
    WERA - 05133164001 - HEX KEY SET, 9PC L-KEY BLACKLASER
05133164001 数据手册
950/9 Hex-Plus Multicolour 2 L-key set, metric, BlackLaser, 9 pieces Innovations and Autumn/Winter Campaign 2019/2020 EAN: 4013288207517 Size: 145x95x30 mm Part number: 05133164001 Weight: 431 g Article number: 950/9 Hex-Plus Multicolour Country of origin: 2 Customs tariff number: CZ 82054000 L-keys for hexagonal socket screws Hex-Plus allows socket head screws to live longer L-keys are quickly to hand thanks to their size markings Wear-resistant size marking Wear-resistant clip material for enhanced durability High quality set of L-keys for hexagonal socket screws in a practical clip made of wear-free material for lasting secure retention of the L-keys, with easy removal when required. Hex-Plus L-keys provide larger contact surfaces on the screw head. The notching effect is thereby reduced to a minimum; the destruction of the screw head is almost eliminated. The ball on the long arm allows safe working even in difficult mounting positions. The BlackLaser surface treatment provides excellent surface protection, corrosion resistance and long life. Laser coated abrasion-resistant size markings on the L-keys for quick access. Web link Wera - 950/9 Hex-Plus Multicolour 2 05133164001 - 4013288207517 Wera Werkzeuge GmbH 07.08.2019 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950/9 Hex-Plus Multicolour 2 L-key set, metric, BlackLaser, 9 pieces Innovations and Autumn/Winter Campaign 2019/2020 Set contents: 950 SPKS Multicolour 05022678001 1 x 1,5 x 50 mm 05022670001 1 x 2 x 56 mm 05022671001 1 x 2,5 x 63 mm 05022672001 1 x 3 x 71 mm 05022673001 1 x 4 x 80 mm 05022674001 1 x 5 x 90 mm 05022675001 1 x 6 x 100 mm 05022676001 1 x 8 x 112 mm 05022677001 1 x 10 x 125 mm L-keys with a thermoplastic sleeve Hex-Plus Ball tip "Take it easy" tool finder system L-keys made from circular material fit into the hand better and allow less strenuous work over a longer period. Additionally, the rubber sleeve provides a pleasant grip, particularly in applications at low temperatures. Colour coding and large stamp enable the desired Lkey to be easily located. Moreover, the round material keys are more robust, particularly where smaller sizes are concerned. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! The spherical drive profile means that it is possible to swivel the axis of the tool to that of the screw, and therefore enable angled, “around-the-corner" screwdriving jobs. "Take it easy" tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). Web link Wera - 950/9 Hex-Plus Multicolour 2 05133164001 - 4013288207517 Wera Werkzeuge GmbH 07.08.2019 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950/9 Hex-Plus Multicolour 2 L-key set, metric, BlackLaser, 9 pieces Innovations and Autumn/Winter Campaign 2019/2020 Secure hold and easy removal The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link Wera - 950/9 Hex-Plus Multicolour 2 05133164001 - 4013288207517 Wera Werkzeuge GmbH 07.08.2019 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05133164001 价格&库存
很抱歉,暂时无法提供与“05133164001”相匹配的价格&库存,您可以联系我们找货
