118154
118154
    WERA(维拉)
118154 数据手册
2067/6 TORX® BO screwdriver set and rack for electronic applications, 6 pieces Series Kraftform Micro EAN: 4013288032294 Size: 205x50x26 mm Part number: 05118154001 Weight: 362 g Article number: 2067/6 TORX® BO Country of origin: CZ Customs tariff number: 82054000 Kraftform Micro screwdriver set for recessed TORX® screws with safety pin Multi-component Kraftform Micro handle with anti-roll feature and swivel cap Includes practical rack for tidy storage of the screwdrivers The Wera Black Point tip offers an exact fit and optimum corrosion protection E.g. for electricians, opticians, precision mechanics, jewellers or IT hardware fitters High quality Wera Micro screwdriver set for precision mechanical work. Suitable for TORX® BO safety screw connections: TORX® BO screws have a protruding pin in their drive profile. This prevents any unauthorised loosening since the “normal” hex tools cannot move these screws. Only special TORX® BO tools have a bore hole which can slip over the pin. Rapid twisting is possible by fixing the hand on the twist cap and using the fast-turning zone just below it. This makes time-consuming grip adjustments unnecessary. Power zone with integrated soft zones ensure the transfer of higher tightening and loosening torque. Precision zone for the right angle for adjustment work. The Wera Black Point tip offers high corrosion protection and an exact fit. Web link http://products.wera.de/en/screwdrivers_series_kraftform_micro_2067_6_torx_bo.html Wera - 2067/6 TORX® BO 05118154001 - 4013288032294 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 2067/6 TORX® BO screwdriver set and rack for electronic applications, 6 pieces Series Kraftform Micro Set contents: 2067 TORX® BO Micro 05118044001 1 x TX 7x60 05118046001 1 x TX 8x60 05118048001 1 x TX 9x60 05118050001 1 x TX 10x60 05118052001 1 x TX 15x60 05118054001 1 x TX 20x60 Kraftform Micro Handle The refined screwdriver for electronics technicians The precision zone Screwdriving jobs in electrical and precision engineering applications are often tedious and timeconsuming. We learned from users what is important for them: working speeds, torque, precision – and we then focused particularly on these issues. Multi-component screwdriver handle for ergonomic working. The Kraftform Micro, with its three zones and their specific arrangement, satisfies these requirements perfectly. The freeturning cap that provides support for the hand works with these advantages, enabling quick and easy precision work. The precision zone directly above the blade gives the user a better feel for the right rotation angle during fine adjustment work. The power zone The fast-turning zone Wera Black Point tip Applications The power zone has integrated soft zones near the blade tip to ensure high torque transfer for loosening or tightening screws without losing contact with the screw. The fast-turning zone just below the rotating cap allows rapid twisting. The Wera Black Point tip and a refined hardening process ensure long service life of the tip, improved corrosion protection and an exact fit. Indispensable for many users, including electronics technicians, opticians, precision engineers, jewellers, EDP hardware fitters and model-makers. Web link http://products.wera.de/en/screwdrivers_series_kraftform_micro_2067_6_torx_bo.html Wera - 2067/6 TORX® BO 05118154001 - 4013288032294 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
118154
- 物料型号:05118154001 - 尺寸:205x50x26 mm - 重量:362 g - 原产地:捷克(CZ) - 海关关税编号:82054000 - 产品特点: - Kraftform Micro螺丝刀套装,适用于嵌入式TORX®螺丝,带有安全销。 - 多组件Kraftform Micro手柄,具有防滚功能和旋转帽。 - 包含实用的支架,用于整齐存放螺丝刀。 - Wera Black Point尖端提供精确配合和最佳防腐保护。 - 功能详解: - 高质量的Wera Micro螺丝刀套装,适用于精密机械工作。 - 适用于TORX® BO安全螺丝连接,具有防止未授权松动的安全销。 - 通过固定在旋转帽上的手和使用旋转帽下方的快速旋转区域,可以实现快速扭转。 - 动力区域集成了软区,确保在拧紧和松开螺丝时传递更高的扭矩。 - 精密区域用于调整工作的正确角度。 - Wera Black Point尖端提供高防腐保护和精确配合。 - 应用信息:适用于电子技术员、光学师、精密机械师、珠宝商、计算机硬件安装工和模型制作者。 - 封装信息:产品包装包括不同尺寸的TORX® BO Micro螺丝刀,具体为TX 7x60、TX 8x60、TX 9x60、TX 10x60、TX 15x60和TX 20x60。
118154 价格&库存
很抱歉,暂时无法提供与“118154”相匹配的价格&库存,您可以联系我们找货
