160I/162I/167I/9
160I/162I/167I/9
    WERA(维拉)
160I/162I/167I/9 数据手册
160 i/162 i/167 i/9 Screwdriver set Kraftform Plus Series 100, 9 pieces Kraftform Plus – Series 100 VDE EAN: 4013288160065 Size: 245x90x61 mm Part number: 05133355001 Weight: 675 g Article number: 160 i/162 i/167 i/9 Country of origin: CZ Customs tariff number: 82054000 Insulated VDE blades for secure work at 1,000 volts Smooth hard zones for high speed turning, soft grip zones for high torque transfer Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Lasertip tips for more secure fit in the screw head 9-piece screwdriver set with individually tested, insulated screwdrivers as per IEC 60900. Individual testing in a water bath at 10,000 volts so as to ensure safe working at the permitted voltage of 1,000 volts. Kraftform Plus handle for pleasant, ergonomic working that makes blisters and calluses a thing of the past. Hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. Partially Lasertip: the tip literally bites itself into the screw head and prevents any slipping. „Take it easy“ Tool Finder: colour coding according to profile and size. The anti-roll feature prevents any bothersome rolling away at the workplace. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_i_162_i_167_i_9.html Wera - 160 i/162 i/167 i/9 05133355001 - 4013288160065 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 160 i/162 i/167 i/9 Screwdriver set Kraftform Plus Series 100, 9 pieces Kraftform Plus – Series 100 VDE Set contents: 162 i PH VDE 05006154001 165 i PZ VDE 05006164001 1 x PH 2x100 165 i PZ/S VDE 05006190001 1 x # 1x80 05006191001 1 x # 2x100 160 i VDE 050061000011) 05006120001 05006120001 1 x PZ 2x100 167 i TORX® VDE 05006172001 1 x TX 15x80 05006174001 1 x TX 20x80 05006176001 1 x TX 25x100 1 x 0.4x2.5x80 1 x 1.0x5.5x125 1 x 1.0x5.5x125 1) without Lasertip Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. Individually tested Impact strength test Lasertip Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. Impact strength tested at −40°C, guaranteeing safety even under extreme conditions. A precisely-focused laser creates a sharp-edged surface structure. This laser treatment results in an edge hardness of up to 1000 HV 0.3. Wera Lasertip “bites” itself into the screw head and prevents any slips out of the recess. It is available for screwdrivers for slotted, Phillips and Pozidriv screws. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_i_162_i_167_i_9.html Wera - 160 i/162 i/167 i/9 05133355001 - 4013288160065 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 160 i/162 i/167 i/9 Screwdriver set Kraftform Plus Series 100, 9 pieces Kraftform Plus – Series 100 VDE Reduced contact pressure PlusMinus screwdrivers Multicomponent Kraftform handle “Take it easy” Toolfinder Wera Lasertip reduces the contact pressure required and enhances force transfer – meaning less screwdriving effort is required. Screwdriving becomes safer and easier. For the use in terminal blocks, control cabinets, switches, relays, sockets etc. Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any “sticking” of the hand to the handle, making rapid repositioning of the hand possible. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_i_162_i_167_i_9.html Wera - 160 i/162 i/167 i/9 05133355001 - 4013288160065 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
160I/162I/167I/9 价格&库存
很抱歉,暂时无法提供与“160I/162I/167I/9”相匹配的价格&库存,您可以联系我们找货
