160IS/7
160IS/7
    WERA(维拉)
160IS/7 数据手册
160 iS/7 Rack screwdriver set Kraftform Plus Series 100, voltage tester and rack. With reduced blade diameter, 7 pieces Kraftform Plus – Series 100 VDE EAN: 4013288160713 Size: 285x210x55 mm Part number: 05006480001 Weight: 711 g Article number: 160 iS/7 Country of origin: CZ Customs tariff number: 82054000 Insulated VDE blades for secure work at 1,000 volts Smooth hard zones for high speed turning, soft grip zones for high torque transfer Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Reduced shaft diameter 7-piece screwdriver set with reduced shaft diameter and integrated insulation protection so that even low-lying screw and spring elements can be accessed and actuated. Kraftform Plus handle for pleasant, ergonomic working that makes blisters and calluses a thing of the past. Hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. "Take it easy" Tool Finder: colour coding according to profile and size. The anti-roll feature prevents any bothersome rolling away at the workplace. Including voltage tester and 1 rack for storage. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_is_7.html Wera - 160 iS/7 05006480001 - 4013288160713 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 160 iS/7 Rack screwdriver set Kraftform Plus Series 100, voltage tester and rack. With reduced blade diameter, 7 pieces Kraftform Plus – Series 100 VDE Set contents: 162 iS 05006450001 05006451001 1 x PH 1x80 1 x PH 2x100 160 iS 05006440001 05006441001 05006442001 1 x 0.6x3.5x100 1 x 0.8x4.0x100 1 x 1.0x5.5x125 Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. 165 iS PZ/S 05006466001 1 x # 2x100 247 050056550011) 1 x 0.5x3.0x70 1) Product not available in the USA and Canada. VDE-insulated screwdriver with reduced blade diameter PlusMinus screwdrivers Individually tested Reduced blade diameter with integrated protective insulation, allows sunken screws and spring elements to be accessed and actuated, individually tested as per IEC 60900. For the use in terminal blocks, control cabinets, switches, relays, sockets etc. Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_is_7.html Wera - 160 iS/7 05006480001 - 4013288160713 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 160 iS/7 Rack screwdriver set Kraftform Plus Series 100, voltage tester and rack. With reduced blade diameter, 7 pieces Kraftform Plus – Series 100 VDE Impact strength test Multicomponent Kraftform handle Prevents hand injuries “Take it easy” Toolfinder Impact strength tested at −40°C, guaranteeing safety even under extreme conditions. Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any “sticking” of the hand to the handle, making rapid repositioning of the hand possible. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_is_7.html Wera - 160 iS/7 05006480001 - 4013288160713 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
160IS/7 价格&库存
很抱歉,暂时无法提供与“160IS/7”相匹配的价格&库存,您可以联系我们找货
