7456 ESD 30 NCM
7456 ESD 30 NCM
    WERA(维拉)
    WERA - 7456 ESD 30 NCM - Torque, Screwdriver, ESD, 0.157" Drive, 138mm Length, 30N-cm
7456 ESD 30 NCM 数据手册
7456 ESD Kraftform pre-set adjustable torque screwdrivers with quick-release chuck, 0,3 - 1,0 Nm ESD Series EAN: 4013288179050 Size: 170x40x40 mm Part number: 05074828001 Weight: 134 g Article number: 7400 ESD vor Halfmoon Country of origin: CZ Customs tariff number: 82054000 Pre-set Kraftform ESD torque screwdriver ESD-safe tool thanks to surface resistance of < 10^9 Ohm Multi-component Kraftform Micro handle for fast and ergonomic screwdriving Suitable for bits with 4 mm halfmoon and 4 mm HIOS drive Distinct audible and perceivable excess load signal when the pre-set torque value is reached Wera torque screwdriver. Secure protection against electrostatic charge and associated damage. Comes with pre-set torque value for all applications where the same, constant torque and repeat accuracy are required. The torque value can be modified within a specific measurement range. Rapidaptor quick-release technology for rapid bit change. Unlimited torque to loosen seized screws. Multi-component Kraftform handle with hard and soft zones for high working speeds, whilst being easy on the hand. Suitable for bits with ¼” hexagon head drive as per DIN ISO 1173-C 6.3 and E 6.3 (ISO 1173). Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_7400_esd_vor_halfmoon.html Wera - 7400 ESD vor Halfmoon 05074828001 - 4013288179050 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 7456 ESD Kraftform pre-set adjustable torque screwdrivers with quick-release chuck, 0,3 - 1,0 Nm ESD Series Wera ESD Tools High protection Pre-set, adjustable torque screwdrivers For Halfmoon and HIOS Bits The requirements for ESD-safe screwdrivers are specified in the European standard DIN EN 61340-5-1. This standard also includes a handle that has to be out of a defined conductive material. The Wera products in the ESD series satisfy these standards and the even more stringent requirements demanded by some technology companies. The electric surface resistance of the Wera ESD material is ≤ 10^9 ohm. This securely protects components against electrostatic energy and associated damage. Pre-set torque, adjustable within a defined range. Also available in ESD version (also for HIOS/Halfmoon bits) and with Kraftform Micro handle. Features a combination bitholder for both bits with Halfmoon and bits with HIOS drive. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_7400_esd_vor_halfmoon.html Wera - 7400 ESD vor Halfmoon 05074828001 - 4013288179050 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 7456 ESD Kraftform pre-set adjustable torque screwdrivers with quick-release chuck, 0,3 - 1,0 Nm ESD Series Kraftform The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. Further versions in this product family: art. no. mm nm nm mm inch 7455 ESD 89 0.015 0.1-0.34 138 5 1/4 05074826010 7455 ESD 89 0.015 0.1-0.34 138 5 1/4 05074828001 7456 ESD 89 0.035 0.3-1.0 138 5 1/4 7456 ESD 89 0.035 0.3-1.0 138 5 1/4 05074826001 1) 1) 05074828010 1) Other pre-set values within the adjustable range can be delivered on request Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_7400_esd_vor_halfmoon.html Wera - 7400 ESD vor Halfmoon 05074828001 - 4013288179050 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
7456 ESD 30 NCM 价格&库存
很抱歉,暂时无法提供与“7456 ESD 30 NCM”相匹配的价格&库存,您可以联系我们找货
