CLICK-TORQUE A 5
CLICK-TORQUE A 5
    WERA(维拉)
    WERA - CLICK-TORQUE A 5 - Torque Wrench, Reversible Ratchet, Square, 0.25 " Drive, 290 mm Length, 2....
CLICK-TORQUE A 5 数据手册
Click-Torque A 5 torque wrench with reversible ratchet, 1/4 inch square, 2.5 - 25 Nm Series Click-Torque Wrenches EAN: 4013288193179 Size: 325x50x50 mm Part number: 05075604001 Weight: 522 g Article number: Click-Torque A 5 Country of origin: TW Customs tariff number: 82041100 With ¼" square drive, reversible ratchet, 45 teeth Easy setting and saving of the desired torque value with audible and tactile clicks when reaching the scale values Audible and tactile release mechanism when the set torque value is reached Measuring range: 2.5-25 Nm; Precise to +/- 4% as per DIN EN ISO 6789-1:2017-07 Very robust design with ergonomic 2-component handle suitable for right-hand use Click-Torque wrench in the unmistakable, robust Wera design with high accuracy as per DIN EN ISO 6789-1: 2017-07. Easy setting and saving of the default value. The audible and tactile clicks on reaching the scale values also facilitate the safe setting of the desired torque value. The robust release mechanism guarantees a clearly audible and tactile release signal when the set torque is reached. For right-hand use (clockwise torquecontrol) and with 45-tooth reversible ratchet mechanism. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_click-torque_a_5.html Wera - Click-Torque A 5 05075604001 - 4013288193179 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Click-Torque A 5 torque wrench with reversible ratchet, 1/4 inch square, 2.5 - 25 Nm Series Click-Torque Wrenches Click-Torque Wrench series Exact Simple and safe Simple setting We wanted working with torque wrenches to be simple and accurate which is why we developed the Click-Torque wrenches. With the ability to set and save the default values and with the unmistakable, robust Wera design, these torque wrenches are the ideal tools for all bolting applications that require torque-controlled tightening (clockwise torque wrenches) and tightening and loosening (torque wrenches for insert tools). Precise to ± 4% as per DIN EN ISO 6789-1:2017-07. Easy setting and saving of the desired torque value; readable on the main and fine scales. With audible and tactile clicks when adjusting the scale values. Release mechanism For right-handed use Robust models When the set torque value is reached, an audible and tactile mechanism triggers. The reversible Click-Torque wrenches are for right-handed use. Very robust design with reversible ratchet (45 teeth) and ergonomic 2-component handle. Further versions in this product family: 05075604001 inch nm nm lbf. ft. mm mm mm mm mm 1/4" 0.10 2.5-25 1-18 290 121 42 25 11.5 inch inch inch 11 4 1 27⁄64" 49⁄64" 21⁄32" inch inch 1 7⁄16" Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_click-torque_a_5.html Wera - Click-Torque A 5 05075604001 - 4013288193179 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Click-Torque A 5 torque wrench with reversible ratchet, 1/4 inch square, 2.5 - 25 Nm Series Click-Torque Wrenches Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_click-torque_a_5.html Wera - Click-Torque A 5 05075604001 - 4013288193179 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
CLICK-TORQUE A 5 价格&库存
很抱歉,暂时无法提供与“CLICK-TORQUE A 5”相匹配的价格&库存,您可以联系我们找货
