05020071001
05020071001
    WERA(维拉)
    WERA - 5020071001 - COMBINATION WRENCH, RACHET, 16MM X 213MM
05020071001 数据手册
Joker Switch Ratcheting combination wrenches, with switch lever, 16 x 213 mm Joker EAN: 4013288184733 Size: 290x50x22 mm Part number: 05020071001 Weight: 195 g Article number: Joker Switch Country of origin: CZ Customs tariff number: 82041100 Practical holding function thanks to the metal plate in the jaw Limit stop prevents any slipping Very fine toothing and robust locking element Ratchet end angled by 15° Take it easy tool finder with colour coding according to sizes Joker ratcheting combination wrenches with angled ratchet head and switch lever. The metal plate in the jaw provides for the holding function which reduces the risk of losing nuts and bolts. The integrated limit stop can prevent any slipping from the bolt head downwards and enables higher torque to be applied. The exchangeable metal plate in the jaw securely holds nuts and bolts with its extra hard teeth and reduces the risk of slipping. The double-hex geometry delivers a very positive connection with nuts or bolts and again provides for a lower risk of any slipping. The low return angle of only 30° at the jaw end avoids any time-consuming flipping of the wrench when fastening. The reversible ratchet mechanism at the ring end with its fine toothing (80 teeth) ensures great flexibility even in confined spaces. Audibly precise ratchet mechanism. Additionally, the robust two-piece locking element provides for an extreme stability. Comes with a 15° angled ratchet end for secure work even at high torque. The special forged geometry allows for high torque transfer and high flexural rigidity. Manufactured out of high-performance chrome-molybdenum steel with a nickelchromium coating for high corrosion protection. With "Take it easy" tool finder: colour coding according to size. Web link http://products.wera.de/en/joker_joker_switch.html Wera - Joker Switch 05020071001 - 4013288184733 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Joker Switch Ratcheting combination wrenches, with switch lever, 16 x 213 mm Joker With the Joker, you can now loosen and tighten nuts and bolts, in situations where conventional tools fail. Particularly in confined spaces, where conventional openjawed wrenches cannot be used. The combination of limit stop and small return angle enables eff ective work, even on screw pipe connections. Joker Switch Angled ratchet end Holding function The direction of the fine-tooth ratchet mechanism can easily be changed via the smooth switch lever. The ratchet end is angled at 15° to the tool axis, making application of the tool in confined spaces much easier. The Joker’s holding function means that nuts and bolts can be held in the jaw and easily positioned where they are needed. Fastening on to the thread can then be done quickly and safely, thanks to the innovative special stop-plate which holds the fastener. No more time-wasting searches for dropped nuts and bolts! After applying and positioning the nut or bolt, fastening can begin immediately – no additional tools required. Web link http://products.wera.de/en/joker_joker_switch.html Wera - Joker Switch 05020071001 - 4013288184733 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Joker Switch Ratcheting combination wrenches, with switch lever, 16 x 213 mm Joker Integrated limit-stop Double-hex geometry Small return angle Fine tooth mechanism Constant re-positioning of the wrench? Difficulty holding fasteners in confined spaces? Easing off to avoid any risks of injury or fastener damage? That was yesterday. Today, the Joker prevents slipping off of the fastener head with its integrated limit-stop – no longer is the thumb needed to act as a depth stop. This makes applications much easier and allows signifi cantly more force to be applied during fastening jobs. The Joker’s clever double-hex geometry delivers a very positive connection with nuts or bolts – it’s a perfect fit. And the exchangeable, hardened metal gripping plate in the Joker’s mouth literally bites itself into the bolt, with its extremely hard tips. Both features combine to prevent slipping, even at higher torque. Instead of 60°, the Joker only has a 30° return angle thanks to it’s unique double-hex design. Along with the Joker’s straight neck, this means that flipping the wrench has become a thing of the past. With the Joker, you can now loosen and tighten nuts and bolts, in situations where conventional tools fail. Particularly in confined spaces, where conventional openjawed wrenches cannot be used. The combination of limit stop and small return angle enables eff ective work, even on screw pipe connections. The ratcheting feature at the ring end boasts an exceptional, fine tooth mechanism – 80 teeth in all – which provides greater flexibility, even in very confined workingspaces. Further versions in this product family: mm mm mm mm mm mm 05020064001 leuchtpink 8 144 20.3 5.5 18 7 05020065001 hellgelb 10 159 23 5.5 21.5 7.5 05020066001 hellblau 11 165.0 24.3 6.3 22 7.5 05020067001 schwarz 12 171 26.3 6.6 25 8.5 05020068001 tuerkis 13 179 27.3 7 26 8.5 05020069001 pink 14 187 30 7.5 28 9.5 05020070001 weiss 15 199 32 7.8 28.8 9.5 05020071001 violett 16 213 35 8.2 31.7 10.5 05020072001 rot 17 225 37 8.5 33 10.5 05020073001 leuchtgruen 18 234 39.5 9 34 11 05020074001 blau 19 246 42 9.5 34.7 11 Web link http://products.wera.de/en/joker_joker_switch.html Wera - Joker Switch 05020071001 - 4013288184733 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05020071001
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款高性能光耦器件,具有高速响应和高隔离电压特性。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚GND,5脚VCC,6脚集电极。
4. 参数特性:工作温度范围为-40至+85摄氏度,隔离电压为5000Vrms,响应时间为10us。
5. 功能详解:EL817通过光电效应实现电信号隔离,常用于开关电源、通信设备等领域。
6. 应用信息:EL817适用于需要高速信号传输和高隔离电压的场合。
7. 封装信息:EL817采用DIP-6封装形式。
05020071001 价格&库存
很抱歉,暂时无法提供与“05020071001”相匹配的价格&库存,您可以联系我们找货
