05021728001
05021728001
    WERA(维拉)
    WERA - 05021728001 - 950 PKL/13 13 Piece SAE SZ N Hex Key Set
05021728001 数据手册
950 PKL/13 SZ N L-key set, imperial, BlackLaser, 13 pieces L-Keys for Hexagon Socket Screws EAN: 4013288111982 Size: 222x86x25 mm Part number: 05021728001 Weight: 463 g Article number: 950/13 Hex-Plus Imperial 1 Country of origin: CZ Customs tariff number: 82054000 L-keys for hexagonal socket screws Hex-Plus allows socket head screws to live longer BlackLaser for high corrosion protection and long service life L-keys are quickly to hand thanks to their size markings Wear-resistant clip material for enhanced durability High quality L-key set for imperial hexagonal socket screws in a practical clip fastener out of wear-resistant material, enabling secure storage of the Lkeys as well as simple removal. Hex-Plus profile: offers a larger contact surface within the screw head. This reduces the notching effects to a minimum and almost completely eliminates the risk of destroying the screw recess. The ball-end on the long arm allows for reliable working even in difficult installation situations. The BlackLaser surface treatment provides outstanding surface protection, even against corrosion, and a long service life. The tools are quickly to hand thanks to the laser-engraved and thereby wear-resistant size markings on the L-keys. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_13_hex-plus_imperial_1.html Wera - 950/13 Hex-Plus Imperial 1 05021728001 - 4013288111982 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 PKL/13 SZ N L-key set, imperial, BlackLaser, 13 pieces L-Keys for Hexagon Socket Screws Set contents: 950 PKL inch 05022068001 05022070001 05022071001 05022072001 05022073001 05022074001 05022076001 05022078001 050220790011) 05022080001 050220810011) 05022082001 05022095001 1 x 5/64x100 1 x 3/32x112 1 x 7/64x119 1 x 1/8x126 1 x 9/64x132 1 x 5/32x140 1 x 3/16x160 1 x 7/32x180 1 x 0.05x83 1 x 1/4x190 1 x 1/16x91 1 x 5/16x200 1 x 3/8x212 1) Regular hexagon L-Keys Hex-Plus Ball tip Surface protection We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! The spherical drive profile means that it is possible to swivel the axis of the tool to that of the screw, and therefore enable angled, “around-the-corner” screwdriving jobs. L-keys with BlackLaser surface treatment for outstanding surface protection and long service life. High corrosion protection. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_13_hex-plus_imperial_1.html Wera - 950/13 Hex-Plus Imperial 1 05021728001 - 4013288111982 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 PKL/13 SZ N L-key set, imperial, BlackLaser, 13 pieces L-Keys for Hexagon Socket Screws Size identification Secure hold and easy removal The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_13_hex-plus_imperial_1.html Wera - 950/13 Hex-Plus Imperial 1 05021728001 - 4013288111982 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05021728001 价格&库存
很抱歉,暂时无法提供与“05021728001”相匹配的价格&库存,您可以联系我们找货
    • 1+338.74130
    库存:294
