05022669001
05022669001
    WERA(维拉)
    WERA - 05022669001 - Hex Key Set, Metric, 9 Piece
05022669001 数据手册
3950 SPKL/9 SM Multicolour L-key set, metric, stainless, 9 pieces Innovations and Autumn/Winter Campaign 2017/2018 EAN: 4013288185211 Size: 234x88x30 mm Part number: 05022669001 Weight: 651 g Article number: 3950/9 Hex-Plus Multicolour Stainless 1 Country of origin: CZ Customs tariff number: 82054000 Solution to the extraneous rust problem: fasten stainless screws with stainless tools Hex-Plus allows socket head screws to live longer Take it easy tool finder with colour coding according to sizes Wear-resistant clip material for enhanced durability Colour coded, easy-to-grip plastic sleeve, even at low temperatures High quality L-key set out of stainless steel for hexagon socket screws by Wera. Stainless steel prevents the transfer of extraneous rust. The Hex-Plus profile offers a greater contact surface in the head of the screw. The notching effect is therefore reduced to a minimum and damage to the screw head more or less eliminated. Come with hex ballpoint on the long arm: the ballpoint drive profile means that it is possible to swivel the tool axis away from the screwdriving axis, thus enabling “round the corner” screwdriving. "Take it easy" Tool Finder: colour coding according to size. In an almost wear-free L-key clip fastener. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_3950_9_hex-plus_multicolour_stainless_1.html Wera - 3950/9 Hex-Plus Multicolour Stainless 1 05022669001 - 4013288185211 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 3950 SPKL/9 SM Multicolour L-key set, metric, stainless, 9 pieces Innovations and Autumn/Winter Campaign 2017/2018 Set contents: 3950 SPKL Multicolour 05022660001 1 x 1.5x90 05022661001 1 x 2.0x101 05022662001 1 x 2.5x112 05022663001 1 x 3.0x123 05022664001 1 x 4.0x137 05022665001 1 x 5.0x154 05022666001 1 x 6.0x172 05022667001 1 x 8.0x195 05022668001 1 x 10.0x224 We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. Stainless L-keys Vacuum ice-hardened Hex-Plus Stainless L-keys are hardened to the same strength as conventional (carbon) steel tools, and prevent extraenous rust forming. The stainless steel tools from Wera are vacuum ice-hardened and have the hardness and strength needed for screw connections. There are no limitations to the industrial applications they are suitable for. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_3950_9_hex-plus_multicolour_stainless_1.html Wera - 3950/9 Hex-Plus Multicolour Stainless 1 05022669001 - 4013288185211 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 3950 SPKL/9 SM Multicolour L-key set, metric, stainless, 9 pieces Innovations and Autumn/Winter Campaign 2017/2018 SPKL L-keys Secure hold and easy removal Take it easy tool finder system Size identification SPKL – protects fingers! L-keys with a thermoplastic sleeve (SPKL) are manufactured out of easy-togrip, circular material. The sleeve ensures that work is safe and comfortable even at low temperatures. High corrosion protection features thanks to the special BlackLaser surface treatment. Colour coding and large stamp to enable the desired L-key to be easily located. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_3950_9_hex-plus_multicolour_stainless_1.html Wera - 3950/9 Hex-Plus Multicolour Stainless 1 05022669001 - 4013288185211 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05022669001 价格&库存
很抱歉,暂时无法提供与“05022669001”相匹配的价格&库存,您可以联系我们找货
    • 1+493.26181
    库存:339
