05057431001
05057431001
    WERA(维拉)
    WERA - 05057431001 - Bit Set, Phillips, Slotted, Torx, 30 Piece
05057431001 数据手册
Bit-Check 30 Diamond 1, 30 pieces Bit-Checks Diamond EAN: 4013288179814 Size: 145x80x25 mm Part number: 05057431001 Weight: 251 g Article number: Bit-Check 30 Diamond 1 Country of origin: CZ Customs tariff number: 82079030 BiTorsion zone to absorb peak loads Enhanced service life of the bits Diamond coating for a secure fit in the screw, literally bites into the screwhead to prevent cam-out Take it easy tool finder: colour coding according to profile and size Bits with tiny diamond particles on the bit tip. This ensures a secure fit in the screw head, reduces the contact pressure required and lowers the risk of slipping. BiTorsion bits with an elastic torsion zone – where kinetic energy is diverted from peak loads – and softer BiTorsion zone to prevent the bit tip from twisting under high strain. This greatly extends the product service life. Comes with Rapidaptor technology, which allows bits to be attached without any need to actuate the sleeve. The removal of the bit is simple, just by pushing the sleeve forward – for rapid bit change with just one hand. For insertion in the power screwdriver or into the chuck of the power drill. The multi-component Bit-Check is convincing on account of its low weight and the maximum possible degree of compactness. In this respect, the soft material in the lower section of the Bit-Check ensures that the bits are securely held whilst being simple to remove at the same time. The profile and size of the bits are easy to recognise thanks to the Wera "Take it easy" Tool Finder with its colour coding and clearly visible imprint. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_diamond_bit-check_30_diamond_1.html Wera - Bit-Check 30 Diamond 1 05057431001 - 4013288179814 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Diamond 1, 30 pieces Bit-Checks Diamond Set contents: 889/4/1 K 05052502001 1 x 1/4"x50 855/1 BDC PZ 05056700001 05056702001 05056704001 2 x PZ 1x25 4 x PZ 2x25 1 x PZ 3x25 800/1 BDC 05056172001 05056174001 05056176001 1 x 0.8x5.5x25 1 x 1.0x5.5x25 1 x 1.2x6.5x25 851/1 BDC PH 05056400001 05056402001 05056404001 2 x PH 1x25 4 x PH 2x25 1 x PH 3x25 867/1 TORX® BDC 05066100001 2 x TX 10x25 05066102001 2 x TX 15x25 05066104001 3 x TX 20x25 05066106001 3 x TX 25x25 05066108001 1 x TX 30x25 05066110001 1 x TX 40x25 At the workplace Bits with diamond coating Slipping out of the head of the screw Secure fit in the screw head The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. The diamond coating of the DC bits lowers the danger of slipping as the minute diamond particles literally “bite” themselves into the screw head. To solve this fundamental problem, Wera launched a diamond-coated bit on to the market in 1992. Today, the Wera diamond bit – manufactured with the technology specifically developed by Wera for this application – still sets the standard in terms of resilience and functionality. Wera bits with a diamond coating ensure a secure fit of the bit in the screw head. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_diamond_bit-check_30_diamond_1.html Wera - Bit-Check 30 Diamond 1 05057431001 - 4013288179814 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Diamond 1, 30 pieces Bit-Checks Diamond Perfect fit Rapid-in and self-lock Rapid-out Magnetic Ideal for sensitive materials The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. Bitholders, magnetic, for easier application of the screw. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_diamond_bit-check_30_diamond_1.html Wera - Bit-Check 30 Diamond 1 05057431001 - 4013288179814 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057431001 价格&库存
很抱歉,暂时无法提供与“05057431001”相匹配的价格&库存,您可以联系我们找货
