Bit-Check 30 Impaktor 1, 30 pieces
Bit-Checks Impaktor
EAN:
4013288156778
Size:
165x85x35 mm
Part number:
05057690001
Weight:
274 g
Article number:
Country of origin:
CZ
Customs tariff
number:
82079030
Upright positionable, multi-component Bit-Check
Impaktor technology for above-average service life
Particularly suitable for use with customary impact drivers
Diamond coating for a secure fit in the screw, literally bites into the screwhead to prevent cam-out
Holder with ring magnet for holding longer and heavier screws
1 Impaktor holder with retaining ring and ring magnet, 29 Impaktor bits. The Impaktor technology offers an above-average service life even under
extreme circumstances thanks to the best possible utilisation of the material properties and the optimised geometry; particularly suitable for use with
customary impact drivers; holder with ring magnet for simple holding of even longer and heavier screws, ideal for overhead work. The rough diamondcoating of the bits reduces the risk of a slipping out of the screw head thanks to the enhanced frictional resistance.
Web link
http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_impaktor_bit-check_30_impaktor_1.html
Wera - Bit-Check 30 Impaktor 1
05057690001 - 4013288156778
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Bit-Checks Impaktor
Set contents:
897/4 Impaktor R
05057676001 1 x 1/4"x75
851/1 IMP DC
05057615001
05057616001
05057617001
2 x PH 1x25
3 x PH 2x25
2 x PH 3x25
855/1 IMP DC
05057620001
05057621001
05057622001
2 x PZ 1x25
3 x PZ 2x25
2 x PZ 3x25
867/1 IMP DC
05057628001
05057623001
05057624001
05057625001
05057626001
05057627001
1 x TX 10x25
1 x TX 15x25
2 x TX 20x25
3 x TX 25x25
2 x TX 30x25
2 x TX 40x25
840/1 IMP DC
05057603001
05057604001
05057605001
05057606001
1 x 3.0x25
1 x 4.0x25
1 x 5.0x25
1 x 6.0x25
Impaktor technology for an aboveaverage service life even under
extreme demands
At the workplace
Improved productivity
Above-average service life
The Bit-Checks can be positioned
upright at the workplace so the
tool is always quickly to hand.
For use with impact screwdrivers.
Improve
productivity
when
screwdriving with power tools.
Maximum utilisation of the
material properties, a very special
geometry – designed particularly
to meet the extreme demands –
as well a specific manufacturing
process mean that Wera Impaktor
tools have an above-average
service life.
Web link
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
Bit-Checks Impaktor
Torsion zone
Impaktor-Bits
Impaktor holder with ring
magnet
TriTorsion system
Torsion zone specially designed to
absorb such forces and thereby
protect the bit tip.
For an above-average service life.
service life. Another product
advantage is the coating of the
Impaktor bits with minute diamond
particles. These diamond particles
reduce the cam-out effects –
particularly high in power tool
applications – which can lead to a
slipping out of the screw head.
The diamond particles literally bite
themselves into the screw recess.
This means that less contact
pressure is required, something
that greatly delays fatigue settingin in power tool screwdriving jobs.
The Impaktor holder with ring
magnet additionally holds longer
and heavier screws absolutely
securely. This enables a speedy
and dependable positioning of the
screw. It is also ideal for abovehead work. Should the magnet
function not be required in a
particular situation e.g. when
working with metal, it can be
extracted from the screwdriving
area and can thereby be
“disabled”. Mainly used in manual
power tool applications.
The combination of the double
torsion zones in the Impaktor
holder and the torsion zone in the
Impaktor bit result in the so-called
TriTorsion system.
Web link
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05057690001”相匹配的价格&库存,您可以联系我们找货
