05059554001
05059554001
    WERA(维拉)
    Hex Driver Bit, Phillips, PH3 Bit, 50 mm Overall
05059554001 数据手册
851/4 BTZ bits, PH 3 x 50 mm Bits for Phillips Screws EAN: 4013288034595 Size: 50x7x6 mm Part number: 05059554001 Weight: 11 g Article number: 851/4 BTZ PH Country of origin: CZ Customs tariff number: 82079030 For Phillips screws Ductile and tough for hard materials BiTorsion zone to absorb peak loads 1/4" hexagon drive (Wera connecting series 4) Take it easy tool finder: colour coding according to profile and size BiTorsion bits for Phillips screws with elastic Torsion zone – where kinetic energy is diverted from peak loads – and softer BiTorsion zone to prevent the bit tip from twisting under peak loads. This greatly extends the product service life. Tough viscous for universal use; ¼” hexagon, suitable for holders as per DIN ISO 1173-F 6.3. Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_phillips_screws_851_4_btz_ph.html Wera - 851/4 BTZ PH 05059554001 - 4013288034595 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 851/4 BTZ bits, PH 3 x 50 mm Bits for Phillips Screws BiTorsion Bits Two cushioning torsion zones BiTorsion phase 1 BiTorsion phase 2 Peak forces that occur in power tool applications often result in premature wear of bits or damage to the screw head. This usually occurs during initial power-up and the when the screw comes to a standstill. Screwdriving could become more productive and safer if these peak loads could be minimised. The Wera BiTorsion system prevents premature wear. The service life of the tool is extended and the productivity of power tool applications significantly increased. The effectiveness of the BiTorsion system comes from a combination of two shock-absorbing spring elements. Both bits as well as holders have a cushioning torsion zone that diverts the kinetic energy away from the drive tip during peak loads. The torsion spring integrated into the unique BiTorsion holder absorbs lower levels of peak loads (Phase 1). Any overloading of this spring is effectively prevented by means of a supporting mechanism. Higher peak loads are minimised through the torsion effect of the bit shaft (Phase 2). This effect is achieved with a specific heat treatment after the hardening process of the bits. This reduces the hardness of the shaft in comparison to the drive tip. Above-average service life BiTorsion and conventional tools Prevents premature wear “Take it easy” tool finder Even the service life of conventional bits is enhanced with the use of the BiTorsion holder and the BiTorsion bit also functions in a normal holder. The BiTorsion holder and the BiTorsion bit can, of course, be used independently of one another. The optimally coordinated features of the torsion zones on the bit and holder permit a phased yield when under strain. The two-phase system prevents premature wear. Moreover, a long tool service life is also ensured by the hardness of the bits that matches the respective application. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_phillips_screws_851_4_btz_ph.html Wera - 851/4 BTZ PH 05059554001 - 4013288034595 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 851/4 BTZ bits, PH 3 x 50 mm Bits for Phillips Screws Further versions in this product family: mm inch 05059550001 PH 1 50 2 05059552001 PH 2 50 2 05059554001 PH 3 50 2 Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_phillips_screws_851_4_btz_ph.html Wera - 851/4 BTZ PH 05059554001 - 4013288034595 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05059554001 价格&库存
很抱歉,暂时无法提供与“05059554001”相匹配的价格&库存,您可以联系我们找货
  • 1+26.643201+3.45780
  • 5+24.988885+3.24310
  • 10+22.4638710+2.91540
