05059910001
05059910001
    WERA(维拉)
    WERA - 05059910001 - Hex Driver Bit, Pozidriv, PZ1 Bit, 50 mm Overall
05059910001 数据手册
855/4 BTH bits, PZ 1 x 50 mm Bits for Pozidriv Screws EAN: 4013288034335 Size: 50x7x6 mm Part number: 05059910001 Weight: 10 g Article number: 855/4 BTH PZ Country of origin: CZ Customs tariff number: 82079030 Suitable for Pozidriv Particularly hard for semi-hard materials BiTorsion zone to absorb peak loads 1/4" hexagon drive (Wera connecting series 4) Take it easy tool finder: colour coding according to profile and size Torsion bits for Pozidriv* screws with elastic Torsion zone – where kinetic energy is diverted from peak loads – and softer BiTorsion zone to prevent the bit tip from twisting under peak loads. This greatly extends the product service life. This provides the best possible durability together with the matching holder. Extra-hard; ¼” hexagon, suitable for holders as per DIN ISO 1173-F 6.3. * Pozidriv = registered trademark of European Industrial Service Ltd. Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_pozidriv_screws_855_4_bth_pz.html Wera - 855/4 BTH PZ 05059910001 - 4013288034335 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 855/4 BTH bits, PZ 1 x 50 mm Bits for Pozidriv Screws BiTorsion Bits Two cushioning torsion zones BiTorsion phase 1 BiTorsion phase 2 Peak forces that occur in power tool applications often result in premature wear of bits or damage to the screw head. This usually occurs during initial power-up and the when the screw comes to a standstill. Screwdriving could become more productive and safer if these peak loads could be minimised. The Wera BiTorsion system prevents premature wear. The service life of the tool is extended and the productivity of power tool applications significantly increased. The effectiveness of the BiTorsion system comes from a combination of two shock-absorbing spring elements. Both bits as well as holders have a cushioning torsion zone that diverts the kinetic energy away from the drive tip during peak loads. The torsion spring integrated into the unique BiTorsion holder absorbs lower levels of peak loads (Phase 1). Any overloading of this spring is effectively prevented by means of a supporting mechanism. Higher peak loads are minimised through the torsion effect of the bit shaft (Phase 2). This effect is achieved with a specific heat treatment after the hardening process of the bits. This reduces the hardness of the shaft in comparison to the drive tip. Above-average service life Prevents premature wear “Take it easy” tool finder BTH- and BTZ-Bits Even the service life of conventional bits is enhanced with the use of the BiTorsion holder and the BiTorsion bit also functions in a normal holder. The optimally coordinated features of the torsion zones on the bit and holder permit a phased yield when under strain. The two-phase system prevents premature wear. Moreover, a long tool service life is also ensured by the hardness of the bits that matches the respective application. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. BTH- (extra-hard) and BTZ- (tough) bits have an additional tempered BiTorsion zone, which reduces the hardness of the shaft by about 20 % in comparison to the drive tip.This means that the peak loads that cause bit breakage and premature wear are absorbed in this zone – something which enhances the service life of the bits. Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_pozidriv_screws_855_4_bth_pz.html Wera - 855/4 BTH PZ 05059910001 - 4013288034335 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 855/4 BTH bits, PZ 1 x 50 mm Bits for Pozidriv Screws Further versions in this product family: mm inch 05059910001 PZ 1 50 2 05059912001 PZ 2 50 2 05059914001 PZ 3 50 2 Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_pozidriv_screws_855_4_bth_pz.html Wera - 855/4 BTH PZ 05059910001 - 4013288034335 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05059910001 价格&库存
很抱歉,暂时无法提供与“05059910001”相匹配的价格&库存,您可以联系我们找货
