167I/6
167I/6
    WERA(维拉)
167I/6 数据手册
167 i/6 Screwdriver set Kraftform Plus Series 100, 6 pieces Kraftform Plus – Series 100 VDE EAN: 4013288160072 Size: 274x122x40 mm Part number: 05133356001 Weight: 351 g Article number: 167 i/6 Country of origin: CZ Customs tariff number: 82054000 Insulated VDE blades for secure work at 1,000 volts Smooth hard zones for high speed turning, soft grip zones for high torque transfer Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Black Point tip for enhanced corrosion protection and an exact fit 6-piece Wera VDE screwdriver set with Multi-component Kraftform Plus handle for fast and low-fatigue working: hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. Individually tested in a water bath at 10,000 volts so as to ensure safe working at the permitted voltage of 1,000 volts. "Take it easy" Tool Finder: colour coding according to profile and size. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_167_i_6.html Wera - 167 i/6 05133356001 - 4013288160072 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 167 i/6 Screwdriver set Kraftform Plus Series 100, 6 pieces Kraftform Plus – Series 100 VDE Set contents: 167 i TORX® VDE 05006169001 1 x TX 9x80 05006170001 1 x TX 10x80 05006172001 1 x TX 15x80 05006174001 1 x TX 20x80 05006176001 1 x TX 25x100 05006184001 1 x TX 8x80 Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. Individually tested Impact strength test Multicomponent Kraftform handle Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. Impact strength tested at −40°C, guaranteeing safety even under extreme conditions. Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any “sticking” of the hand to the handle, making rapid repositioning of the hand possible. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_167_i_6.html Wera - 167 i/6 05133356001 - 4013288160072 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 167 i/6 Screwdriver set Kraftform Plus Series 100, 6 pieces Kraftform Plus – Series 100 VDE Prevents hand injuries Rapid hand repositioning “Take it easy” Toolfinder Non-roll feature The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin “sticking” to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. All Kraftform screwdrivers have a non-roll feature at the lower end of the handle. The hexagonal design prevents any annoying rolling away of the screwdriver at the workplace. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_167_i_6.html Wera - 167 i/6 05133356001 - 4013288160072 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
167I/6 价格&库存
很抱歉,暂时无法提供与“167I/6”相匹配的价格&库存,您可以联系我们找货
