367/6 HF
367/6 HF
    WERA(维拉)
    WERA  367/6 HF  SCREWDRIVER SET, HOLDING FUNCTION
367/6 HF 数据手册
367/6 TORX® HF Kraftform Plus screwdriver set with holding function and rack, 6 pieces Kraftform Plus – Series 300 EAN: 4013288100764 Size: 285x210x55 mm Part number: 05028059001 Weight: 749 g Article number: 367/6 TORX® HF Country of origin: CZ Customs tariff number: 82054000 Screwdriver for TORX® screws; holding function Multi-component Kraftform handle for fast and ergonomic screwdriving Handle markings simplify finding and sorting of tools Hexagonal anti-roll feature against rolling away Holding function for TORX® screws, chrome-plated 6-piece screwdriver set for TORX® screws. Multi-component Kraftform handle for fast and low-fatigue working. Kraftform Plus: hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. Holding function: the wedging forces resulting from the contact pressure between the drive tip and the screw profile securely hold the screw on the tool. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace. Handle markings for simplified finding and sorting of the tool. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_367_6_torx_hf.html Wera - 367/6 TORX® HF 05028059001 - 4013288100764 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 367/6 TORX® HF Kraftform Plus screwdriver set with holding function and rack, 6 pieces Kraftform Plus – Series 300 Set contents: 367 TORX® HF 05028050001 05028051001 05028052001 05028053001 05028055001 05028056001 Kraftform Plus screwdrivers – ergonomics you can grasp. They relieve the entire hand-arm system even when used intensively. Along with other technical and product advantages such as the Lasertip for a secure fit in the screw head, Kraftform screwdrivers are the ideal choice whenever manual screwdriving jobs are concerned. 1 x TX 10x80 1 x TX 15x80 1 x TX 20x100 1 x TX 25x100 1 x TX 30x115 1 x TX 40x130 TORX® HF profile Kraftform Prevents hand injuries In tight assembly or disassembly situations, for example in engine compartments, it is not possible to securely hold the screw with the hand on the screwdriver, and the screw subsequently often gets lost. Lengthy searches or the loss of the screw (with the associated danger that could bring about) are the consequence. The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that the screw is securely held on the tool! The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_367_6_torx_hf.html Wera - 367/6 TORX® HF 05028059001 - 4013288100764 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 367/6 TORX® HF Kraftform Plus screwdriver set with holding function and rack, 6 pieces Kraftform Plus – Series 300 Rapid hand repositioning Large contact area Identification marking Non-roll feature The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin “sticking” to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. The large contact area – with particularly high friction to the soft zones – results in high torque transfer without any bruising from the edges. The screw symbol and tip size identification markings on the handle make it easier to find the right screwdriver in the tool case or at the workplace. The hexagonal non-roll feature prevents any rolling away at the workplace. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_367_6_torx_hf.html Wera - 367/6 TORX® HF 05028059001 - 4013288100764 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
367/6 HF 价格&库存
很抱歉,暂时无法提供与“367/6 HF”相匹配的价格&库存,您可以联系我们找货
