5073278001
5073278001
    WERA(维拉)
    WERA - 5073278001 - COMBINATION WRENCH, RACHET, 18MM X 235MM
5073278001 数据手册
Joker Ratcheting combination wrenches, # 18 Combination ratchet wrenches EAN: 4013288167408 Size: 310x50x22 mm Part number: 05073278001 Weight: 252 g Article number: Joker Country of origin: CZ Customs tariff number: 82041100 Practical holding function thanks to the metal plate in the jaw Limit stop prevents any slipping The double-hex geometry reduces the risk of slipping Return angle of only 30° Take it easy tool finder with colour coding according to sizes High quality combination ratchet wrench by Wera. Everything that a wrench has to be able to do. And a whole lot more. Faster, better, stylish. Yes, a real Joker. The new generation of combination ratchet wrenches. Suitable for hexagon socket screws, bolts or nuts. Comes with holding function, thanks to the metal plate in the jaw, which reduces the risk of dropping nuts and bolts. The replaceable metal plate in the jaw secures nuts and bolts with its extra hard teeth and reduces the danger of slipping. The integrated limit stop prevents any slipping around the bolt head and allows higher torque to be applied. The double-hex geometry makes for a positive connection with nuts or bolts and reduces the risk of slipping. A return angle of only 30° at the open end prevents any time consuming flipping of the wrench. The ratchet mechanism at the ring end, with an exceptional, fine-tooth mechanism – 80 teeth in all – enables flexibility even in very confined working spaces. The specially forged geometry ensures high torque transfer and strength. The ratchet is manufactured out of high performance chrome molybdenum steel with nickel-chrome coating for high corrosion protection. "Take it easy" Tool Finder with colour coding according to sizes. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_combination_ratchet_wrenches_joker.html Wera - Joker 05073278001 - 4013288167408 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Joker Ratcheting combination wrenches, # 18 Combination ratchet wrenches The ratcheting feature at the ring end boasts an exceptional, fine tooth mechanism – 80 teeth in all – which provides greater flexibility, even in very confined working spaces. Joker open-ended wrench Holding function Integrated limit-stop When we began to think about open-ended wrenches, we asked ourselves: why does the wrench always have to be flipped over; why does it have an offset design; why does it slip off injuring fingers? The new design of the mouth resulted in a real “Joker” that works even when all other trumps have been played. The Joker’s holding function means that nuts and bolts can be held in the jaw and easily positioned where they are needed. Fastening on to the thread can then be done quickly and safely, thanks to the innovative special stop-plate which holds the fastener. No more time-wasting searches for dropped nuts and bolts! After applying and positioning the nut or bolt, fastening can begin immediately – no additional tools required. Constant re-positioning of the wrench? Difficulty holding fasteners in confined spaces? Easing off to avoid any risks of injury or fastener damage? That was yesterday. Today, the Joker prevents slipping off of the fastener head with its integrated limit-stop – no longer is the thumb needed to act as a depth stop. This makes applications much easier and allows signifi cantly more force to be applied during fastening jobs. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_combination_ratchet_wrenches_joker.html Wera - Joker 05073278001 - 4013288167408 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Joker Ratcheting combination wrenches, # 18 Combination ratchet wrenches Double-hex geometry Small return angle Fine tooth mechanism “Take it easy” tool finder The Joker’s clever double-hex geometry delivers a very positive connection with nuts or bolts – it’s a perfect fit. And the exchangeable, hardened metal gripping plate in the Joker’s mouth literally bites itself into the bolt, with its extremely hard tips. Both features combine to prevent slipping, even at higher torque. Instead of 60°, the Joker only has a 30° return angle thanks to it’s unique double-hex design. Along with the Joker’s straight neck, this means that flipping the wrench has become a thing of the past. With the Joker, you can now loosen and tighten nuts and bolts, in situations where conventional tools fail. Particularly in confined spaces, where conventional openjawed wrenches cannot be used. The combination of limit stop and small return angle enables eff ective work, even on screw pipe connections. The ratcheting feature at the ring end boasts an exceptional, fine tooth mechanism – 80 teeth in all – which provides greater flexibility, even in very confined workingspaces. Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). Further versions in this product family: mm mm mm mm mm mm 05073268001 leuchtpink 8 144 20 5.5 18 7 05073270001 hellgelb 10 159 22 5.5 21 7.2 05073271001 hellblau 11 165.0 25 6.3 22 7.5 05073272001 schwarz 12 170.7 26.3 6.6 25 8.5 05073273001 tuerkis 13 177 27.3 7 25 8.6 05073274001 pink 14 188 29.3 7.5 28 9.2 05073275001 weiss 15 200 32.3 7.8 28.5 9.2 05073276001 violett 16 212 35 8.2 32.7 10.5 05073277001 rot 17 224 37.2 8.5 32.7 10.5 05073278001 leuchtgruen 18 235 39 9 33.8 11 05073279001 blau 19 246 42 9.5 34.8 11 Web link http://products.wera.de/en/tools_for_the_aerospace_segment_combination_ratchet_wrenches_joker.html Wera - Joker 05073278001 - 4013288167408 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
5073278001 价格&库存
很抱歉,暂时无法提供与“5073278001”相匹配的价格&库存,您可以联系我们找货
