5200995001
5200995001
    WERA(维拉)
    WERA - 5200995001 - Tool-Check Automotive Bits with Ratchet and Sockets
5200995001 数据手册
Tool-Check Automotive 1, 38 pieces Zyklop Mini EAN: 4013288165343 Size: 218x81x51 mm Part number: 05200995001 Weight: 478 g Article number: Tool-Check Automotive 1 Country of origin: CZ Customs tariff number: 82079030 1/4" bit ratchet, tough-absorbing bits, Rapidaptor holder, adaptor and 1/4" sockets Ideal for working in confined spaces Tough viscous bits for universal use Use of 1/4" sockets also possible with the Wera adaptor 870/1 Take it easy tool finder: colour coding according to profile and size Ratchet, bits and sockets in a minimum of space – as compact as it gets. Comes with a practical clip for attachment e.g. to the belt so the ToolCheck is always at hand even for mobile applications. Simple operation, even with just one hand, in confined working spaces. Drop-forged, full-steel design and fine-pitched mechanism with 60 teeth that allows a small return angle of 6° for precise working. Easy left/right switchover. Ergonomically designed ratchet head and lever. Suitable for ¼” bit and socket take-up. The use of ¼” sockets is also possible with the Wera adaptor 870/1. Tough viscous bits for universal use. Manual and power tool socket insert (ISO 2725-Part 3) by Wera allows applications both in manual as well as power tools. "Take it easy" Tool Finder with colour coding according to size - for simple and rapid accessing of the required tool. Featuring a good grip to allow easy pick-up even with oily hands. Ball stop groove, for hex head bolts and nuts; chrome vanadium steel, matt chrome-plated. Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_tool-check_automotive_1.html Wera - Tool-Check Automotive 1 05200995001 - 4013288165343 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Tool-Check Automotive 1, 38 pieces Zyklop Mini Set contents: 8001 A 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 889/4/1 K 05052502001 1 x 1/4"x50 870/1 051360000011) 1 x 1/4"x25 1) With friction ball; for manual nut spinner sockets 851/1 TZ PH 05056505001 05056510001 05056525001 1 x PH 1x25 1 x PH 2x25 1 x PH 3x25 867/1 TZ TORX® 05066305001 1 x TX 10x25 05066308001 1 x TX 15x25 05066310001 1 x TX 20x25 05066312001 1 x TX 25x25 05066315001 1 x TX 30x25 05066320001 1 x TX 40x25 867/1 Z TORX® BO 05066500001 1 x TX 10x25 05066505001 1 x TX 15x25 05066510001 1 x TX 20x25 05066515001 1 x TX 25x25 05066525001 1 x TX 30x25 800/1 TZ 05056225001 840/1 Z Hex-Plus 05056315001 1 x 3.0x25 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 05056330001 1 x 6.0x25 05056335001 1 x 8.0x25 1 x 1.0x5.5x25 860/1 XZN Vielzahn 05066150001 1 x M 4x25 05066155001 1 x M 5x25 05066160001 1 x M 6x25 05066165001 1 x M 8x25 8790 HMA 05003504001 05003505001 05003506001 05003507001 05003509001 05003511001 05003512001 873/1 Five Lobe 05066603001 1 x 20x25 05066604001 1 x 25 1 x 5.5x23.0 1 x 6.0x23.0 1 x 7.0x23.0 1 x 8.0x23.0 1 x 10.0x23.0 1 x 12.0x23.0 1 x 13.0x23.0 Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_tool-check_automotive_1.html Wera - Tool-Check Automotive 1 05200995001 - 4013288165343 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Tool-Check Automotive 1, 38 pieces Zyklop Mini The Zyklop Mini Ratchets Small return angle Simple direction change Combines elegant design with incredible resilience. Suitable for rapid fastening even in confined working situations. The Wera Zyklop Mini is applied whenever fastening with a power tool or conventional tools is impossible due to insufficient space. The Zyklop Mini 1 for the direct attachment of bits; the Zyklop Mini 2 for the direct attachment of the special Wera Zyklop sockets. For all applications. The fine tooth mechanism, with its 60 teeth, allows a small return angle of only 6° – ideal for precision work. Simple switching between left/right operations. Is rapid screwdriving possible with the Zyklop Mini? Zyklop Mini tool sets Slim design Take it easy tool finder system High working speeds can be attained with the Zyklop Mini. The thumb wheel is important, enabling more rapid screwdriving, and the Zyklop Mini hande only needs to be used for the final tightening of the screw. Available in a set with the dependable Wera Bit-Check with socket adaptor and belt clip. Simple fitting and removal of tools. Very robust and a long service life. Its slim design makes it ideal for all particularly confined working situations. Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). difficult-to-access Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_tool-check_automotive_1.html Wera - Tool-Check Automotive 1 05200995001 - 4013288165343 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
5200995001 价格&库存
很抱歉,暂时无法提供与“5200995001”相匹配的价格&库存,您可以联系我们找货
