8100 SA ALL-IN
8100 SA ALL-IN
    WERA(维拉)
    8100 SA ALL-IN
8100 SA ALL-IN 数据手册
8100 SA All-in Zyklop Speed Ratchet Set, 1/4" drive, with holding function, metric, 42 pieces The Zyklop Speed Ratchets, 1/4" EAN: 4013288190994 Size: 220x140x70 mm Part number: 05003755001 Weight: 1240 g Article number: 8100 SA All-In Country of origin: CZ Customs tariff number: 82041100 Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8100_sa_all-in.html Wera - 8100 SA All-In 05003755001 - 4013288190994 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA All-in Zyklop Speed Ratchet Set, 1/4" drive, with holding function, metric, 42 pieces The Zyklop Speed Ratchets, 1/4" 42-piece ratchet set in robust textile box Freely pivoting ratchet head with 5 predefined locking positions Bit-sockets with all the advantages of the Wera bit technology Incredibly compact set arrangement with many tools in a minimum of space. A completely new ratchet set feeling thanks to the unique textile boxes that are very robust and durable. They can be positioned upright for tidy storage on the workshop shelf. Additional surface protection due to textile outer material. Low weight and volume for simpler mobility. "Take it easy" Tool Finder with colour coding according to sizes. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8100_sa_all-in.html Wera - 8100 SA All-In 05003755001 - 4013288190994 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA All-in Zyklop Speed Ratchet Set, 1/4" drive, with holding function, metric, 42 pieces The Zyklop Speed Ratchets, 1/4" Set contents: 8000 A 05003500001 1 x 1/4"x152.0 8794 A 05003527001 1 x 1/4"x56.0 8767 A HF 05003360001 05003361001 05003362001 05003363001 05003364001 05003365001 05003367001 05003369001 05003371001 1 x TX 8x28.0 1 x TX 9x28.0 1 x TX 10x28.0 1 x TX 15x28.0 1 x TX 20x28.0 1 x TX 25x28.0 1 x TX 27x28.0 1 x TX 30x28.0 1 x TX 40x28.0 8740 A HF 05003332001 05003333001 05003335001 05003337001 05003341001 05003339001 1 x 3.0x28.0 1 x 4.0x28.0 1 x 5.0x28.0 1 x 6.0x28.0 1 x 7.0x28.0 1 x 8.0x28.0 8755 A 05003353001 05003354001 05003355001 1 x PZ 1x28.0 1 x PZ 2x28.0 1 x PZ 3x28.0 8796 LA 05003531001 1 x 1/4"x150.0 8790 HMA HF 05003717001 05003718001 05003719001 05003720001 05003721001 05003722001 05003723001 05003724001 05003725001 05003726001 05003727001 05003728001 05003729001 1 x 4.0x23.0 1 x 4.5x23.0 1 x 5.0x23.0 1 x 5.5x23.0 1 x 6.0x23.0 1 x 7.0x23.0 1 x 8.0x23.0 1 x 9.0x23.0 1 x 10.0x23.0 1 x 11.0x23.0 1 x 12.0x23.0 1 x 13.0x23.0 1 x 14.0x23.0 8740 A 05003330001 05003331001 1 x 2.0x28.0 1 x 2.5x28.0 8751 A 05003350001 05003351001 05003352001 1 x PH 1x28.0 1 x PH 2x28.0 1 x PH 3x28.0 8700 A FL 05003320001 05003322001 1 x 0.8x5.5x28.0 1 x 1.2x6.5x28.0 Mutterentnahme-Werkzeug 05050005001 1 x 43.0x14.0 Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8100_sa_all-in.html Wera - 8100 SA All-In 05003755001 - 4013288190994 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA All-in Zyklop Speed Ratchet Set, 1/4" drive, with holding function, metric, 42 pieces The Zyklop Speed Ratchets, 1/4" Zyklop “6 in 1” Bit sockets with holding function for TORX® screws Bit sockets with retaining function for hexagon socket screws Incredibly fast ¼” Zyklop Speed ratchet with pivoting ratchet head and 5 predefined locking positions 1. Fine-tooth ratchet 2. Flex-head ratchet 3. Angle ratchet 4. Quickrelease ratchet 5. Power ratchet 6. Screwdriver The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that TORX® screws made according to Acument Intellectual Properties specifications are securely held on the tool! The clamping of the screw is achieved by a flexible locking ball. The holding function is especially helpful in confined, hard-to-reach spaces, where there is no room for a second hand to secure the screw. Sockets with retaining function for hexagon headed bolts, screws and nuts “Take it easy” tool finder Nut extractor tool Secure hold and easy removal The clamping of the screw is achieved by a twin spring loaded ball retention system. The tubing is effectively protected against mechanical wear and tear by a steel ring. The holding function is especially helpful in confined, hardto-reach spaces, where there is no room for a second hand to secure the screw. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. This tool enables hexagon nuts to be easily removed from sockets with holding function. The all new smooth turning mechanism guarantees both secure and rattle-free storage, yet allows easy removal of the tool. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8100_sa_all-in.html Wera - 8100 SA All-In 05003755001 - 4013288190994 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
8100 SA ALL-IN 价格&库存
很抱歉,暂时无法提供与“8100 SA ALL-IN”相匹配的价格&库存,您可以联系我们找货
