8100 SC 2
8100 SC 2
    WERA(维拉)
    WERA - 8100 SC 2 - 1/2" Drive 37 Piece Metric Zyklop Ratchet Set in a High Density Foam-lined Metal ...
8100 SC 2 数据手册
8100 SC 2 Zyklop Speed ratchet set, 1/2" drive, metric, 37 pieces The Zyklop Ratchets, 1/2" EAN: 4013288121189 Size: 355x315x70 mm Part number: 05003645001 Weight: 6340 g Article number: 8100 SC 2 Country of origin: CZ Customs tariff number: 82041200 Combines five different types of a ratchet in one 37-piece set in a robust metal case Freely pivoting ratchet head Take it easy tool finder with colour coding according to sizes 37-piece Zyklop set in robust metal case: Zyklop ratchet with 1/2"drive. The 72 fine-pitched teeth enable a low return angle of only 5°. The ratchet head pivots freely and can be locked into any position by using the slide switch that is positioned on either side. It is even possible to work conveniently in very confined and difficult-to-access areas with enhanced hand clearance. The predefined locking positions at 0°, 15° und 90°, both to the right and left, ensure safe working without any slipping of the ratchet head. The ratchet can be used as a conventional screwdriver in the 0° position by attaching an adaptor and a bit. The flywheel design ensures rapid screwdriving. The rotation-symmetric construction of the Kraftform handle and the free-turning sleeve support rapid twisting. The outstanding design of the Kraftform handle fits perfectly into the hand preventing hand injuries such as blisters and calluses. The hard materials used for the handle ensure quick and easy hand repositioning without any danger of the skin "sticking" to the handle. The softer anti-slip zones enable the low-loss transfer of high torque. For 1/2" square sockets as well as 1/2" adaptors with square drive, equipped with ball lock. Including 17 Zyklop sockets, 2 Zyklop extensions with free-turning sleeve, 1 T-handle, 1 wobble extension, 1 adaptor with quick-release chuck, 13 bits. "Take it easy" Tool Finder with colour coding according to sizes. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_1_2_8100_sc_2.html Wera - 8100 SC 2 05003645001 - 4013288121189 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SC 2 Zyklop Speed ratchet set, 1/2" drive, metric, 37 pieces The Zyklop Ratchets, 1/2" Set contents: 8000 C 05003600001 1 x 1/2"x277.0 8790 HMC 05003601001 05003602001 05003603001 05003604001 05003605001 05003606001 05003607001 05003608001 05003609001 05003610001 05003611001 05003612001 05003613001 05003614001 05003615001 05003616001 05003617001 1 x 10.0x37.0 1 x 11.0x37.0 1 x 12.0x37.0 1 x 13.0x37.0 1 x 14.0x37.0 1 x 15.0x37.0 1 x 16.0x37.0 1 x 17.0x37.0 1 x 18.0x37.0 1 x 19.0x37.0 1 x 20.0x37.0 1 x 21.0x37.0 1 x 22.0x37.0 1 x 24.0x37.0 1 x 27.0x40.0 1 x 30.0x42.0 1 x 32.0x42.0 8789 C 05003636001 1 x 1/2"x250.0 8794 C 05003639001 1 x 1/2"x52.0 8795 C 05003640001 1 x 1/2"x69.0 8784 C2 05003641001 1 x 5/16x1/2"x50.0 8796 SC 05003642001 1 x 1/2"x125.0 8796 LC 05003643001 1 x 1/2"x250.0 851/2 Z PH 05057715001 1 x PH 3x32 855/2 Z PZ 05058015001 1 x PZ 3x32 867/2 Z TORX® 05066900001 05066901001 05066905001 05066910001 05066915001 05066920001 05066925001 1 x TX 25x35 1 x TX 20x35 1 x TX 30x35 1 x TX 40x35 1 x TX 45x35 1 x TX 50x35 1 x TX 55x35 840/2 Z 05057515001 05057520001 05057525001 05057530001 1 x 5x30 1 x 6x30 1 x 8x30 1 x 10x30 Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_1_2_8100_sc_2.html Wera - 8100 SC 2 05003645001 - 4013288121189 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SC 2 Zyklop Speed ratchet set, 1/2" drive, metric, 37 pieces The Zyklop Ratchets, 1/2" The Zyklop Speed Ratchet Pivots freely Fast movers Incredibly fast ¼” Zyklop Speed ratchet with pivoting ratchet head and 5 predefined locking positions The Wera Zyklop Speed ratchet combines the advantages of five different types of ratchet in one. And it is a really fast mover. The ratchet head pivots freely and can be locked into any defined position by using the slide switch that is positioned on either side. It is even possible to work in very confined and difficult-to-access areas with enhanced hand clearance. The predefined locking at 0°, 15° and 90°, both to the right and left, ensure safe working without any slipping of the ratchet head. The Zyklop Speed ratchets are really fast movers. The gyrating mass design means that screwdriving is accelerated. The rotation-symmetric structure of the Kraftform handle and the freeturning sleeve reinforce this rapid twisting process, particularly when the ratchet does not engage due to too little resistance in the thread. Simple direction change Low return angle Screwdriver Two-tone foam insert All Zyklop Speed ratchets feature a thumbwheel that can be used to quickly and easily switch between clockwise and anticlockwise rotation, at any position. No complicated handling, no loss of time! The reversible ratchet with 72 finepitched teeth has a low return angle of only 5°. This short stroke allows fast and precise work in all types of installation. The ratchet can be used as a conventional screwdriver in the 0° position by attaching a bitholding adaptor and a bit. Perfectly conceived in every detail: the storage case for the Zyklop Speed ratchet sets! The two-tone foam insert section means that the tools can be quickly and reliably replaced, and that missing tools can be detected immediately. The tools and their position can be clearly seen in the lid where they have been laser-etched, ensuring that they are legible even when the insert section is covered with grease, dirt or oil. Additionally, the foam section can be removed and placed in the drawer of a tool cabinet or trolley. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_1_2_8100_sc_2.html Wera - 8100 SC 2 05003645001 - 4013288121189 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SC 2 Zyklop Speed ratchet set, 1/2" drive, metric, 37 pieces The Zyklop Ratchets, 1/2" Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_1_2_8100_sc_2.html Wera - 8100 SC 2 05003645001 - 4013288121189 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
8100 SC 2 价格&库存
很抱歉,暂时无法提供与“8100 SC 2”相匹配的价格&库存,您可以联系我们找货
