8740 5 X 28MM
8740 5 X 28MM
    WERA(维拉)
    WERA - 8740 5 X 28MM - Hex Driver Bit, Hex, 5mm, 28mm
8740 5 X 28MM 数据手册
8740 A HF Zyklop bit socket with 1/4" drive with holding function, 5.0 x 28 mm Innovations and Autumn/Winter Campaign 2017/2018 EAN: 4013288187192 Size: 95x44x20 mm Part number: 05003335001 Weight: 19 g Article number: 8740 A HF Country of origin: CZ Customs tariff number: 82079030 Hex-Plus allows socket head screws to live longer Take it easy tool finder with colour coding according to sizes The holding function holds screws securely on the tool Knurling on lower end for more grip when used manually Bit socket (non-impact) for manual or machine tool operations Bit socket with 1/4 inch drive and holding function for extremely convenient screwdriving with reduced risk of losing the screw when addressing the workpiece. "Take it easy" Tool Finder with colour coding according to size - for simple and rapid accessing of the required tool. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8740_a_hf.html Wera - 8740 A HF 05003335001 - 4013288187192 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8740 A HF Zyklop bit socket with 1/4" drive with holding function, 5.0 x 28 mm Innovations and Autumn/Winter Campaign 2017/2018 Bit sockets with retaining function for hexagon socket screws Bit sockets with retaining function for hexagon socket screws Hex-Plus Take it easy tool finder system The clamping of the screw is achieved by a flexible locking ball. The holding function is especially helpful in confined, hard-to-reach spaces, where there is no room for a second hand to secure the screw. The clamping of the screw is achieved by a flexible locking ball. The holding function is especially helpful in confined, hard-to-reach spaces, where there is no room for a second hand to secure the screw. Hexagon socket screws are a problem, because the contact surfaces that transfer the force of the tool to the screw are very narrow. The consequence: the head of the screw can be damaged, usually rounding out the recess. Hex-Plus tools have larger contact surfaces to prevent this, driving from the flats of the recess, rather than the corners. Good to know: Hex-Plus tools fit into every standard hexagon socket screw! Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8740_a_hf.html Wera - 8740 A HF 05003335001 - 4013288187192 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8740 A HF Zyklop bit socket with 1/4" drive with holding function, 5.0 x 28 mm Innovations and Autumn/Winter Campaign 2017/2018 Manual and machine sockets Zyklop Accessories The manual and machine sockets can be used both for hand and power tools use (non-impact). Users need just one socket set for all applications. We did not just want our creativity to end with the ratchets themselves so we also occupied ourselves intensively with ratchet accessories. That is why our users are now provided with an extension with freely spinning sleeve and flexible lock to enable more secure and more rapid screwdriving. The sockets have been completely redesigned: we wanted to spare the user the need of having two different series – one for manual and the other for power tool applications. And: we wanted to enormous simplify the task of finding the right sizes. Technically, our own ambitious goals represented a real challenge: to endow sockets with the advantage of the holding function on screwdrivers and bits. We succeeded in this! Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8740_a_hf.html Wera - 8740 A HF 05003335001 - 4013288187192 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8740 A HF Zyklop bit socket with 1/4" drive with holding function, 5.0 x 28 mm Innovations and Autumn/Winter Campaign 2017/2018 Further versions in this product family: mm inch mm mm mm mm 05003332001 leuchtpink 3.0 28.0 12.0 12.5 11.0 05003333001 gelb 4.0 28.0 12.0 12.5 11.0 05003334001 gelb 4.0 100.0 12.0 12.5 83.0 05003335001 leuchtorange 5.0 28.0 12.0 12.5 11.0 05003336001 leuchtorange 5.0 100.0 12.0 12.5 83.0 05003337001 rot 6.0 28.0 12.0 12.5 11.0 05003338001 rot 6.0 100.0 12.0 12.5 83.0 05003341001 violett 7.0 28.0 12.0 12.5 11.0 05003342001 violett 7.0 100.0 12.0 12.5 83.0 05003339001 pink 8.0 28.0 12.0 12.5 11.0 05003340001 pink 8.0 100.0 12.0 12.5 83.0 05003383001 leuchtpink 1/8 28.0 12.0 12.5 11.0 05003384001 weiss 9/64 28.0 12.0 12.5 11.0 05003385001 gelb 5/32" 28.0 12.0 12.5 11.0 05003386001 leuchtorange 3/16" 28.0 12.0 12.5 11.0 05003387001 rot 7/32" 28.0 12.0 12.5 11.0 05003388001 tuerkis 1/4" 28.0 12.0 12.5 11.0 05003389001 pink 5/16" 28.0 12.0 12.5 11.0 Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8740_a_hf.html Wera - 8740 A HF 05003335001 - 4013288187192 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
8740 5 X 28MM 价格&库存
很抱歉,暂时无法提供与“8740 5 X 28MM”相匹配的价格&库存,您可以联系我们找货
