8767 B HF 1
8767 B HF 1
    WERA(维拉)
    WERA - 8767 B HF 1 - Socket Set, 3/8 " Drive, Holding Function, Zyklop Series, 6 Piece - Socket Set,...
8767 B HF 1 数据手册
8767 B TORX® HF 1 Zyklop bit socket set, with holding function, 3/8" drive, 6 pieces Zyklop Accessories, 3/8" EAN: 4013288195074 Size: 155x130x50 mm Part number: 05003185001 Weight: 513 g Article number: 8767 B HF 1 Country of origin: CZ Customs tariff number: 82079030 Bit sockets with holding function for TORX® screws The holding function holds screws securely on the tool Take it easy tool finder with colour coding according to sizes Knurling on lower socket end for more grip when used manually Chrome vanadium steel, matt chrome-plated Bit socket with 3/8 inch drive and holding function for extremely convenient screwdriving with reduced risk of losing the screw when addressing the workpiece. "Take it easy" Tool Finder with colour coding according to size - for simple and rapid accessing of the required tool. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8767_b_hf_1.html Wera - 8767 B HF 1 05003185001 - 4013288195074 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8767 B TORX® HF 1 Zyklop bit socket set, with holding function, 3/8" drive, 6 pieces Zyklop Accessories, 3/8" Set contents: 8767 B HF 05003063001 05003065001 05003067001 05003069001 05003071001 05003073001 1 x TX 25x107.0 1 x TX 27x107.0 1 x TX 30x107.0 1 x TX 40x107.0 1 x TX 45x100.0 1 x TX 50x100.0 Bit sockets with holding function for TORX® screws Zyklop Accessories Take it easy tool finder system Manual and machine sockets The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that TORX® screws made according to Acument Intellectual Properties specifications are securely held on the tool! We did not just want our creativity to end with the ratchets themselves so we also occupied ourselves intensively with ratchet accessories. That is why our users are now provided with an extension with freely spinning sleeve and flexible lock to enable more secure and more rapid screwdriving. The sockets have been completely redesigned: we wanted to spare the user the need of having two different series – one for manual and the other for power tool applications. And: we wanted to enormous simplify the task of finding the right sizes. Technically, our own ambitious goals represented a real challenge: to endow sockets with the advantage of the holding function on screwdrivers and bits. We succeeded in this! Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). The manual and machine sockets can be used both for hand and power tools use (non-impact). Users need just one socket set for all applications. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8767_b_hf_1.html Wera - 8767 B HF 1 05003185001 - 4013288195074 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
8767 B HF 1 价格&库存
很抱歉,暂时无法提供与“8767 B HF 1”相匹配的价格&库存,您可以联系我们找货
