ICEBREAKER
ICEBREAKER
    WERA(维拉)
    WERA - ICEBREAKER - Tool Kit, 32 PC
ICEBREAKER 数据手册
Icebreaker, 32 pieces Limited Editions - when they're gone, they're gone EAN: 4013288221100 Size: 0x0x0 mm Part number: 05134023001 Weight: 0g Article number: Eisbrecher Country of origin: CZ Customs tariff number: 82054000 Promotional set with 30 Stainless tools for the most common applications Completely suitable for industrial use. All Wera Stainless tools are vacuum ice hardened and therefore have the required hardness and strength properties With robust ice scraper by the Finnish specialist KUNGS® - in a Tool Rebel mitten Screwdrivers (TORX® as well as slotted, Philips-head Phillips and Pozidriv with Lasertip tip for better hold on the screw head), L-keys (Hex-Plus reduces the cylindrical turning of hexagonal socket screws), bits, bit holder and iconic Wera bottle opener Also makes a great Christmas present This tool set is not only an icebreaker, it also hits the nail on the head. 32-piece tool set with a special extra for freezing winter nights: one original KUNGS® ice scraper with a warm mitten in the Tool Rebel design. It will let you break stubborn ice on small and large panes and you will be the proud owner of a well sought-after item. With Stainless tools, coming out of the cold, thanks to their vacuum ice hardening, and therefore completely suitable for industrial use and even prevent extraneous rust: 11 screwdrivers, 9 L-keys for exagonal socket screws, 9 bits and a Rapidaptor bit holder. Of course, a must and also included is the ice-blue bottle opener: Skål! Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_limited_editions_-_when_theyre_gone_theyre_gone_eisbrecher.html Wera - Eisbrecher 05134023001 - 4013288221100 Wera Werkzeuge GmbH 02.09.2021 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Icebreaker, 32 pieces Limited Editions - when they're gone, they're gone Set contents: 3350 PH 05032021001 05032022001 1 x PH 1 x 80 mm 1 x PH 2 x 100 mm 3355 PZ 05032031001 05032032001 3367 TX 05032053001 05032054001 05032055001 1 x TX 15 x 80 mm 1 x TX 20 x 100 mm 1 x TX 25 x 100 mm 3335 050320010011),1),1) 1 x 0.5 x 3 x 80 mm 05032003001 1 x 0.8 x 4 x 100 mm 050320040011) 1 x 1 x 5.5 x 125 mm 1 x PZ 1 x 80 mm 1 x PZ 2 x 100 mm 1) without Lasertip 3160 i VDE 05022730001 1 x 0.6 x 3.5 x 100 mm 3888/4/1 K 05071100001 1 x 1/4" x 50 mm 3855/1 TS PZ 05071020001 05071021001 1 x PZ 1 x 25 mm 2 x PZ 2 x 25 mm 3950 PKL 05022700001 05022701001 05022702001 05022703001 05022704001 05022705001 05022706001 05022708001 05022709001 1 x 1.5 x 90 mm 1 x 2 x 101 mm 1 x 2.5 x 112 mm 1 x 3 x 123 mm 1 x 4 x 137 mm 1 x 5 x 154 mm 1 x 6 x 172 mm 1 x 8 x 195 mm 1 x 10 x 224 mm 3851/1 TS PH 05071011001 1 x PH 2 x 25 mm 3867/1 TS TORX® 05071032001 1 x TX 10 x 25 mm 05071033001 1 x TX 15 x 25 mm 05071034001 1 x TX 20 x 25 mm 05071035001 1 x TX 25 x 25 mm 05071037001 1 x TX 30 x 25 mm Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_limited_editions_-_when_theyre_gone_theyre_gone_eisbrecher.html Wera - Eisbrecher 05134023001 - 4013288221100 Wera Werkzeuge GmbH 02.09.2021 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Icebreaker, 32 pieces Limited Editions - when they're gone, they're gone Tool Rebel glove with ice scraper Screw stainless steel together with stainless steel! Hex-Plus With the KUNGS® ice scraper on the Tool Rebel glove, ice is removed effectively without damaging the surface. The glove keeps your hands warm even in sub-zero temperatures. Solution to the rust problem: screw stainless steel together with stainless steel! Wera stainless steel tools are manufactured out of stainless steel so unsightly rust can be avoided. Hexagon socket screws are a problem, because the contact surfaces that transfer the force of the tool to the screw are very narrow. The consequence: the head of the screw can be damaged, usually rounding out the recess. Hex-Plus tools have larger contact surfaces to prevent this, driving from the flats of the recess, rather than the corners. Good to know: Hex-Plus tools fit into every standard hexagon socket screw! Secure hold and easy removal Stainless Steel Bits At the workplace “Take it easy” Tool Finder The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Wera stainless steel bits are manufactured out of stainless steel so unsightly rust can be avoided. The stainless steel bits from Wera are vacuum ice-hardened and have the hardness and strength needed for screw connections. There are no limitations to the industrial applications they are suitable for. The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. Screwdrivers with "Take it easy" tool finder: colour coding according to profile and size stamp. Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_limited_editions_-_when_theyre_gone_theyre_gone_eisbrecher.html Wera - Eisbrecher 05134023001 - 4013288221100 Wera Werkzeuge GmbH 02.09.2021 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
ICEBREAKER 价格&库存
很抱歉,暂时无法提供与“ICEBREAKER”相匹配的价格&库存,您可以联系我们找货
