6004 Joker XL self-setting spanner, 19-24 x 3/4-15/16" x 256 mm
6004 Joker self-setting, adjustable spanner
EAN:
4013288216915
Size:
275x50x26 mm
Part number:
05020104001
Weight:
387 g
Article number:
6004 Joker XL
Country of origin:
CZ
Customs tariff
number:
82041100
The adjustable Joker 6004 covers all metric and imperial dimensions in the respective field of application
Automatic and continuous grip of hexagon screws and bolts
Lever mechanism when gripping avoids slipping and damage
Fast and consistent screwdriving without removing the wrench thanks to mechanical ratchet function
Return angle of only 30° through placement in the corner-width rectangular prisms in the mouth
Many users wish to have a universal screwdriving tool with the widest possible range of applications. It should be a single tool for
multiple metric and imperial dimensions. It should automatically adjust to the different screw sizes. It should be safe to grab without
damaging anything and should allow for high working speeds. With its continuous and parallel jaws the Joker 6004 replaces several
single spanner sizes. The required size is automatically and continuously set when attaching the tool to the hexagon bolt or screw. The
integrated lever mechanism securely clamps the hexagon screw or bolt between the jaws, which significantly reduces the risk of
slippage or damage. The ratchet feature ensures fast and consistent screwdriving without removing the tool. By using the corner-width
rectangular prisms, a back-pivoting angle of only 30° can be achieved. The single-arm design, in conjunction with the ratchet feature
and the corner-width prism, makes it possible to work even in confined spaces. The adjustable Joker 6004 is the universal screwdriving
tool. Self-setting. Gripping. Spanning.
Web link
https://products.wera.de/en/joker_6004_joker_self-setting_adjustable_spanner_6004_joker_xl.html
Wera - 6004 Joker XL
05020104001 - 4013288216915
Wera Werkzeuge GmbH
27.02.2021 - 1 / 2
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Automatically and continuously
self-setting
Gentle to the screw
Ratchet mechanism for fast
work
With its automatically and
continuously gripping parallel jaws
the Joker spanner 6004 covers all
of
application.
The
tool
automatically finds the required
size when placed on the bolt or
screw, no setting required.
The parallel smooth jaws of the
Joker 6004 allow surface pressure
and can thus prevent rounding of
the bolt or screw head, which can
occur during power transmission
on corners.
The ratchet function in the mouth
sees to fast and consistent
tool.
Small return angle
Useful hole for hanging
Thanks to the corner-width
rectangular prisms, a return angle
of only 30° can be realized.
Thanks to its hole the Joker can be
neatly hung on the workshop wall.
Further versions in this product family:
05020104001
mm
inch
mm
mm
19-24
3/4"-15/16"
256
16
Web link
Wera Werkzeuge GmbH
27.02.2021 - 2 / 2
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05020104001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+588.431871+76.47840
- 2+551.741822+71.70980
- 4+496.532864+64.53430
