05056161001
05056161001
    WERA(维拉)
    WERA - 5056161001 - BIT-CHECK SET W/UNIVERSAL HOLDER, 10PC
05056161001 数据手册
Bit-Check 10 Universal 1, 10 pieces Bit-Checks / Bit-Safes Universal EAN: 4013288033772 Size: 97x65x15 mm Part number: 05056161001 Weight: 91 g Article number: Bit-Check 10 Universal 1 Country of origin: CZ Customs tariff number: 82079030 Upright positionable Bit-Checks convince due to their functionality in a minimum of space Universal holder with quick-release chuck for rapid bit change Torsion design against premature wear Tough viscous bits for universal use In handy and robust Bit-Check Robust Bit-Check by Wera. Bit-Checks provide a quick overview of the tools available. Bits not needed are simply reinserted into the set and do not get lost. Simple transportation e.g. in the shirt pocket. Includes universal holder with strong permanent magnet and quick-release chuck for the takeup of bits with ¼” hexagon head drive as per DIN ISO 1173-C 6.3. Can be inserted in the power screwdriver or for use in the chuck of the electric drill. Comes with Torsion bits to combat premature wear; tough viscous for universal use. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_10_universal_1.html Wera - Bit-Check 10 Universal 1 05056161001 - 4013288033772 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 10 Universal 1, 10 pieces Bit-Checks / Bit-Safes Universal Set contents: 895/4/1 K 05053872001 1 x 1/4"x52 855/1 TZ PZ 05056810001 05056815001 05056825001 1 x PZ 1x25 1 x PZ 2x25 1 x PZ 3x25 At the workplace TZ-Bits The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. TZ-Bits are tough viscous bits with a torsion zone. Torsion bits absorb the damaging peak torque loads in the torsion zone. This prevents premature wear and enhances the service life of the bits. 851/1 TZ PH 05056505001 05056510001 05056525001 1 x PH 1x25 1 x PH 2x25 1 x PH 3x25 800/1 TZ 05056220001 05056225001 05056233001 1 x 0.8x5.5x25 1 x 1.0x5.5x25 1 x 1.2x6.5x25 Bit Ranges For a firm, wobble-free connection between holder and bit with quickrelease action. Simply push sleeve forward to change bits. The magnetic design enables simplified positioning of the screw. We have had bit ranges in our programme for many years now. In 2016, we put a question mark against everything and came up with a game changer. We wanted bit ranges with bits whose profiles and sizes could be more easily recognised. We wanted bit ranges that were as compact as possible and which were Wera-like at a first glance. We wanted bit ranges with bits that could be removed and reinserted more easily. We wanted bit ranges with as little weight as possible. The new multicomponent Bit-Checks satisfy these requirements; the soft material in the lower section of the Bit-Checks ensures that the bits are firmly held yet easy to remove. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_10_universal_1.html Wera - Bit-Check 10 Universal 1 05056161001 - 4013288033772 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05056161001 价格&库存
很抱歉,暂时无法提供与“05056161001”相匹配的价格&库存,您可以联系我们找货
