05056440001
05056440001
    WERA(维拉)
    WERA - 5056440001 - BIT-CHECK SET W/UNIVERSAL HOLDER, 31PC
05056440001 数据手册
Bit-Check 30 Universal 1, 30 pieces Bit-Checks / Bit-Safes Universal EAN: 4013288115096 Size: 165x90x35 mm Part number: 05056440001 Weight: 305 g Article number: Bit-Check 30 Universal 1 Country of origin: CZ Customs tariff number: 82079030 Upright positionable, multi-component Bit-Check Rapidaptor holder for rapid bit change Universal bits for all fields of application Rapidaptor technology for rapid bit change Tough viscous bits for universal use 29 bits in a minimum of space; simple removal and reinsertion of the bits. Rapidaptor holder ensures rapid bit change. Universal bits fitted for diverse applications; robust Bit-Check. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_30_universal_1.html Wera - Bit-Check 30 Universal 1 05056440001 - 4013288115096 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Universal 1, 30 pieces Bit-Checks / Bit-Safes Universal Set contents: 889/4/1 K 05052502001 1 x 1/4"x50 855/1 TH PZ 05056910001 05056915001 05056925001 2 x PZ 1x25 3 x PZ 2x25 1 x PZ 3x25 851/1 TZ PH 05056505001 05056510001 05056525001 2 x PH 1x25 3 x PH 2x25 1 x PH 3x25 867/1 TZ TORX® 05066305001 1 x TX 10x25 05066308001 1 x TX 15x25 05066310001 1 x TX 20x25 05066312001 1 x TX 25x25 05066315001 1 x TX 30x25 05066320001 1 x TX 40x25 867/1 Z TORX® BO 05066500001 1 x TX 10x25 05066505001 1 x TX 15x25 05066510001 1 x TX 20x25 05066515001 1 x TX 25x25 05066525001 1 x TX 30x25 800/1 TZ 05056225001 1 x 1.0x5.5x25 840/1 Z Hex-Plus 05056315001 1 x 3.0x25 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 05056330001 1 x 6.0x25 05056335001 1 x 8.0x25 At the workplace Torsion bits Rapidaptor holder The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. Torsion bits absorb the damaging peak torque loads in the torsion zone. This prevents premature wear and enhances the service life of the bits. Rapid bit change without needing any additional tools. One-hand operation with a freely spinning sleeve for simplified guidance of the tool. Also available in a BiTorsion design. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_30_universal_1.html Wera - Bit-Check 30 Universal 1 05056440001 - 4013288115096 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Universal 1, 30 pieces Bit-Checks / Bit-Safes Universal Rapid-in and self-lock Rapid-out Magnetic Chuck-all The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. Bitholders, magnetic, for easier application of the screw. The Rapidaptor quick-release chucks hold ¼" DIN ISO 1173-C 6,3 and E 6,3 as well as Wera series 1 and 4 bits. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_30_universal_1.html Wera - Bit-Check 30 Universal 1 05056440001 - 4013288115096 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05056440001 价格&库存
很抱歉,暂时无法提供与“05056440001”相匹配的价格&库存,您可以联系我们找货
