05056473001
05056473001
    WERA(维拉)
    WERA - 05056473001 - Hex Bit Set, Phillips, Torx, Pozidrive, PH2, T15 - T25, PZ1, PZ2, 6 Piece
05056473001 数据手册
Bit-Check 6 Universal 2, 6 pieces Bit-Checks / Bit-Safes Universal EAN: 4013288156136 Size: 69x65x12 mm Part number: 05056473001 Weight: 76 g Article number: Bit-Check 6 Universal 2 Country of origin: CZ Customs tariff number: 82079030 Upright positionable, multi-component Bit-Check The Torsion design absorbs torque peaks Tough viscous bits for universal use Bit-Check plastic material ensures robustness and durability Prevents premature breakage of the drive tip 6 50 mm-long Wera bits tidily arranged in a minimum of space in a practical Bit-Check. The tough viscous bits are suitable for universal use. In the case of the Torsion bits (TZ), torque peaks are additionally absorbed in the Torsion zone. This prevents premature wear and enhances the service life. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_6_universal_2.html Wera - Bit-Check 6 Universal 2 05056473001 - 4013288156136 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 6 Universal 2, 6 pieces Bit-Checks / Bit-Safes Universal Set contents: 851/4 TZ PH 05059810001 855/4 TZ PZ 05060005001 05060010001 1 x PH 2x50 1 x PZ 1x50 1 x PZ 2x50 867/4 Z TORX® 05060133001 1 x TX 15x50 05060134001 1 x TX 20x50 05060135001 1 x TX 25x50 At the workplace TZ-Bits Bit Ranges The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. TZ-Bits are tough bits with a torsion zone. Torsion bits absorb the damaging peak torque loads in the torsion zone. This prevents premature wear and enhances the service life of the bits. We have had bit ranges in our programme for many years now. In 2016, we put a question mark against everything and came up with a game changer. We wanted bit ranges with bits whose profiles and sizes could be more easily recognised. We wanted bit ranges that were as compact as possible and which were Wera-like at a first glance. We wanted bit ranges with bits that could be removed and reinserted more easily. We wanted bit ranges with as little weight as possible. The new multicomponent Bit-Checks satisfy these requirements; the soft material in the lower section of the Bit-Checks ensures that the bits are firmly held yet easy to remove. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_6_universal_2.html Wera - Bit-Check 6 Universal 2 05056473001 - 4013288156136 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05056473001 价格&库存
很抱歉,暂时无法提供与“05056473001”相匹配的价格&库存,您可以联系我们找货
