05074800001
05074800001
    WERA(维拉)
    WERA - 05074800001 - Torque, Screwdriver, Adjustable, 0.157 " Drive, 131 mm Length, 0.02N-m to 0.11N...
05074800001 数据手册
1460 Kraftform Micro ESD pre-set adjustable torque screwdrivers with quickrelease chuck, 0.02 - 0.06 Nm ESD Series EAN: 4013288168351 Size: 128x18x18 mm Part number: 05074800001 Weight: 22 g Article number: 1460 Micro ESD Country of origin: CZ Customs tariff number: 82054000 Pre-set Kraftform Micro ESD torque screwdriver with quick-release chuck ESD-safe tool thanks to surface resistance of < 10^9 Ohm Distinct audible and perceivable excess load signal when the pre-set torque value is reached Suitable for the take-up of bits with 4 mm halfmoon drive and 4 mm HIOS drive Applications e.g. on smartphones, mobile phones, cameras, electronic equipment Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1460_micro_esd.html Wera - 1460 Micro ESD 05074800001 - 4013288168351 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1460 Kraftform Micro ESD pre-set adjustable torque screwdrivers with quickrelease chuck, 0.02 - 0.06 Nm ESD Series Torque tool with pre-set torque of 3.5 cNm (accuracy +- 10%) as recommended by leading smartphone manufacturers. Compact handle/interchangeable blade system for torque controlled precision screwdriving. The Kraftform Micro ESD torque screwdriver is ideal for torque controlled jobs on electrostatically-susceptible components. Suitable for the take-up of bits with 4 mm halfmoon drive (Wera series 9) and 4 mm HIOS drive (Wera series 21). Tamperproof. Distinct audible and perceivable excess load signal when the pre-set torque value is reached. Unlimited manual loosening torque. Electrical surface resistance of < 109 Ohm for secure protection against electrostatic charge. Manufactured in accordance with DIN EN 61340-5-1. Handle/Interchangeable blade system for rapid blade change. Kaftform Micro handle with twist cap and free-turning zone for rapid twisting, making any time-consuming repositioning of the fingers unnecessary. Power zone with integrated soft zones for the transfer of higher tightening and loosening torque. Precision zone directly above the blade for the right angle for adjustment work. Rapid fixing of the bit: just push the bit into the insert for automatic locking and a secure fit. To change the bit, simply push the sleeve forward and remove. Free-turning sleeve for simple guidance of the tool during the screwdriving process. Bits suitable for manual as well as power tool operations with electric screwdrivers (e.g. HIOS, Delvo, Sehan). Applications for example on smartphones, cell phones, cameras, electrical appliances, in dental labs and dental surgeries. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1460_micro_esd.html Wera - 1460 Micro ESD 05074800001 - 4013288168351 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1460 Kraftform Micro ESD pre-set adjustable torque screwdrivers with quickrelease chuck, 0.02 - 0.06 Nm ESD Series Wera ESD Tools Pre-set, adjustable Torque Screwdrivers For Halfmoon and HIOS Bits The requirements for ESD-safe screwdrivers are specified in the European standard DIN EN 61340-5-1. This standard also includes a handle that has to be out of a defined conductive material. The Wera products in the ESD series satisfy these standards and the even more stringent requirements demanded by some technology companies. These tools are ideal for all applications where a constant, identical torque is required and where a high degree of repeat accuracy is needed. The torque value can be adjusted within the measuring range. Features a combination bitholder for both bits with Halfmoon and bits with HIOS drive. The power zone The precision zone The fast-turning zone The power zone has integrated soft zones near the blade tip to ensure high torque transfer for loosening or tightening screws without losing contact with the screw. The precision zone directly above the blade gives the user a better feel for the right rotation angle during fine adjustment work. The fast-turning zone just below the rotating cap allows rapid twisting. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1460_micro_esd.html Wera - 1460 Micro ESD 05074800001 - 4013288168351 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1460 Kraftform Micro ESD pre-set adjustable torque screwdrivers with quickrelease chuck, 0.02 - 0.06 Nm ESD Series Further versions in this product family: art. no. nm nm mm inch 1460 ESD 0.035 0.02-0.06 131 5 1/4 05074800010 1460 ESD 0.035 0.02-0.06 131 5 1/4 05074810001 1461 ESD 0.050 0.05-0.11 131 5 1/4 1461 ESD 0.050 0.05-0.11 131 5 1/4 05074800001 1) 1) 05074810010 1) Other pre-set values within the adjustable range can be delivered on request Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1460_micro_esd.html Wera - 1460 Micro ESD 05074800001 - 4013288168351 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05074800001 价格&库存
很抱歉,暂时无法提供与“05074800001”相匹配的价格&库存,您可以联系我们找货
库存:7
