05004048001
05004048001
    WERA(维拉)
    WERA - 05004048001 - METAL-SWITCH RATCHET & SOCKET SET, 30PC
05004048001 数据手册
8100 SB 8 Zyklop Metal Ratchet Set with switch lever, 3/8" drive, metric, 29 pieces The Zyklop Ratchets, 3/8" EAN: 4013288173928 Size: 265x120x60 mm Part number: 05004048001 Weight: 1553 g Article number: 8100 SB 8 Country of origin: CZ Customs tariff number: 82041200 Convenient direction change thanks to switchover lever Extremely slim ratchet with long lever Return angle of only 5° Very robust without any restrictions on torque Take it easy tool finder with colour coding according to sizes Incredibly compact set arrangement with many tools in a minimum of space. A completely new ratchet set feeling thanks to the unique textile boxes that are very robust and durable. They can be positioned upright for tidy storage on the workshop shelf. Additional surface protection due to textile outer material. Low weight and volume for simpler mobility. "Take it easy" Tool Finder with colour coding according to sizes. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_8.html Wera - 8100 SB 8 05004048001 - 4013288173928 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 8 Zyklop Metal Ratchet Set with switch lever, 3/8" drive, metric, 29 pieces The Zyklop Ratchets, 3/8" Set contents: 8004 B 05004034001 1 x 3/8"x222.0 8794 LB 05003583001 1 x 3/8"x200.0 8784 B1 05003590001 1 x 1/4"x3/8"x44.0 855/1 Z PZ 05072080001 05072082001 1 x PZ 1x25 1 x PZ 2x25 8790 HMB 05003553001 05003555001 05003557001 05003558001 05003560001 05003561001 05003562001 05003563001 05003564001 1 x 8.0x29.0 1 x 10.0x29.0 1 x 12.0x29.0 1 x 13.0x29.0 1 x 15.0x29.0 1 x 16.0x30.0 1 x 17.0x30.0 1 x 18.0x30.0 1 x 19.0x30.0 8794 B 05003584001 1 x 3/8"x76.0 851/1 Z PH 05072070001 05072072001 05072074001 1 x PH 1x25 1 x PH 2x25 1 x PH 3x25 867/1 TORX® 05066486001 05066487001 05066488001 05066489001 05066490001 05066491001 1 x TX 15x25 1 x TX 20x25 1 x TX 25x25 1 x TX 27x25 1 x TX 30x25 1 x TX 40x25 840/1 Z Hex-Plus 05056315001 1 x 3.0x25 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 05056330001 1 x 6.0x25 05056335001 1 x 8.0x25 Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_8.html Wera - 8100 SB 8 05004048001 - 4013288173928 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 8 Zyklop Metal Ratchet Set with switch lever, 3/8" drive, metric, 29 pieces The Zyklop Ratchets, 3/8" Zyklop Metal Switch The Zyklop Ratchet Metal Switch Reversible Due to the ever-more confined working environment, space is becoming more and more an issue for the application of ratchets. Our product developers therefore intensively occupied themselves with the issue of confined working spaces, and Wera has now solved this problem. The extremely slim and robust Zyklop Metal ratchet with a long lever was what emerged. When the change in direction needs to be quick, the Zyklop Metal Switch ratchet is the right tool. When the socket must not get lost and a coincidental change of direction has to be avoided at all cost, the Zyklop Metal Push is the correct choice. Extremely slim. Long leverage. With switch lever. Switch lever for convenient change of direction. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_8.html Wera - 8100 SB 8 05004048001 - 4013288173928 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 8 Zyklop Metal Ratchet Set with switch lever, 3/8" drive, metric, 29 pieces The Zyklop Ratchets, 3/8" Small return angle Textile boxes Fine-pitched with 72 teeth for a return angle of only 5° The textile boxes offer dramatically improved portability, and are spacesaving to boot! This means you can now carry the same collection of tools, in a much more compact and comfortable package. The hassle of running back and forth for the right tools has now become a thing of the past. And the much lower weight of a set makes carrying more convenient than ever before. The textile box including the tool will even survive a fall undamaged. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_8.html Wera - 8100 SB 8 05004048001 - 4013288173928 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05004048001 价格&库存
很抱歉,暂时无法提供与“05004048001”相匹配的价格&库存,您可以联系我们找货
    • 1+1224.07365
    库存:38
