05028015001
05028015001
    WERA(维拉)
    WERA - 05028015001 - TORX SCREWDRIVER, T30, 115MM
05028015001 数据手册
367 TORX® Screwdriver for TORX® screws, TX 30 x 115 mm Kraftform Plus – Series 300 EAN: 4013288004277 Size: 220x37x37 mm Part number: 05028015001 Weight: 92 g Article number: 367 TORX® Country of origin: CZ Customs tariff number: 82054000 Screwdriver for recessed TORX® screws Multi-component Kraftform handle for fast and ergonomic screwdriving Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away The Wera Black Point tip offers an exact fit and optimum corrosion protection High quality Kraftform Plus screwdriver. Multi-component Kraftform handle for fast and low-fatigue working. Kraftform Plus: hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. The Wera Black Point tip and a complex hardening process ensure a long service life of the tip, enhanced corrosion protection and an exact fit. "Take it easy" Tool Finder: colour coding according to profile and size. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_367_torx.html Wera - 367 TORX® 05028015001 - 4013288004277 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 367 TORX® Screwdriver for TORX® screws, TX 30 x 115 mm Kraftform Plus – Series 300 Kraftform Rapid hand repositioning Large contact area Kraftform Plus screwdrivers – ergonomics you can grasp. They relieve the entire hand-arm system even when used intensively. Along with other technical and product advantages such as the Lasertip for a secure fit in the screw head, Kraftform screwdrivers are the ideal choice whenever manual screwdriving jobs are concerned. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin “sticking” to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. The large contact area – with particularly high friction to the soft zones – results in high torque transfer without any bruising from the edges. Non-roll feature Identification marking Wera Black Point tip The hexagonal non-roll feature prevents any rolling away at the workplace. The screw symbol and tip size identification markings on the handle make it easier to find the right screwdriver in the tool case or at the workplace. The Wera Black Point tip and a refined hardening process ensure long service life of the tip, improved corrosion protection and an exact fit. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_367_torx.html Wera - 367 TORX® 05028015001 - 4013288004277 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 367 TORX® Screwdriver for TORX® screws, TX 30 x 115 mm Kraftform Plus – Series 300 Further versions in this product family: mm mm mm inch 05028000001 TX 5 60 70 3.5 2 3/8 05028001001 TX 6 60 70 3.5 2 3/8 05028002001 TX 7 60 70 3.5 2 3/8 05028003001 TX 8 60 81 3.5 2 3/8 05028004001 TX 9 60 81 4.0 2 3/8 05028005001 TX 10 80 81 4.0 3 1/8 05028008001 TX 15 80 98 4.0 3 1/8 05028010001 TX 20 100 98 4.5 4 05028012001 TX 25 100 105 5.0 4 05028013001 TX 27 115 105 5.5 4 9/16 05028015001 TX 30 115 105 6.0 4 9/16 05028020001 TX 40 130 112 7.0 5 1/8 05028025001 TX 45 130 112 8.0 5 1/8 Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_367_torx.html Wera - 367 TORX® 05028015001 - 4013288004277 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05028015001
物料型号: - 产品型号:367 TORX® - 部件编号:05028015001 - 条形码:4013288004277
器件简介: - 这是一把适用于TORX®螺丝的螺丝刀,属于Kraftform Plus系列300。 - 产品具有多组分Kraftform手柄,提供快速且符合人体工学的螺丝拧紧体验。
引脚分配/参数特性: - 尺寸:220x37x37 mm - 重量:92克 - 国家:捷克 - 关税编号:82054000
功能详解: - Wera Black Point尖端提供精确配合和最佳防腐蚀保护。 - 拥有高质的Kraftform Plus螺丝刀,硬握区域适用于高工作速度,而软区域确保高扭矩传递。 - “轻松工具查找”:根据轮廓和大小进行颜色编码。 - 六边形防滚动功能防止在工作场所滚动。
应用信息: - 适用于手动拧紧螺丝的工作。
封装信息: - 文档还提供了不同版本的产品家族列表,包括不同的尺寸和规格。
05028015001 价格&库存
很抱歉,暂时无法提供与“05028015001”相匹配的价格&库存,您可以联系我们找货
    • 1+100.30608
    库存:45
    05028015001
    • 1+96.573951+12.55430
    • 3+90.576103+11.77460
    • 5+81.535885+10.59940
    库存:6
