05057111001
05057111001
    WERA(维拉)
    WERA - 05057111001 - Bit Set, Security, Kraftform Kompakt Series, Hex, Spanner, Torx, Socket, Tri-wi...
05057111001 数据手册
Kraftform Kompakt 71 security, 32 pieces Kraftform Kompakt 70 and 71 EAN: 4013288038661 Size: 160x115x40 mm Part number: 05057111001 Weight: 522 g Article number: KK 71 Security Country of origin: CZ Customs tariff number: 82079030 32-piece set Strong permanent magnet Rapidaptor quick-release chuck allows rapid bit change Tough viscous bits for universal use In a robust storage box 32-piece set with holder 816 R Kraftform and Rapidaptor quick-release chuck; multi-component Kraftform handle for low-fatigue working. Rapidaptor universal holder with strong permanent magnet that also holds large and heavy screws securely. Together with the 30 bits, the user is equipped for almost every application. Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_70_and_71_kk_71_security.html Wera - KK 71 Security 05057111001 - 4013288038661 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt 71 security, 32 pieces Kraftform Kompakt 70 and 71 Set contents: 816 R 05051462001 889/4/1 K 05052502001 1 x 1/4"x119 1 x 1/4"x50 867/1 Z TORX® BO 05066497001 1 x TX 7x25 05066498001 1 x TX 8x25 05066499001 1 x TX 9x25 05066500001 1 x TX 10x25 05066505001 1 x TX 15x25 05066510001 1 x TX 20x25 05066515001 1 x TX 25x25 05066525001 1 x TX 30x25 05066530001 1 x TX 40x25 840/1 Z Hex-Plus BO 05056341001 1 x 2.0x25 05056342001 1 x 2.5x25 05056343001 1 x 3.0x25 05056344001 1 x 4.0x25 05056345001 1 x 5.0x25 05056346001 1 x 6.0x25 868/1 Z 05066400001 05066405001 05066410001 05066415001 871/1 TORQ-SET® Mplus 25 mm 05066628001 1 x 6x25 05066630001 1 x 8x25 05066632001 1 x 10x25 05066633001 1 x 0x1/4x25 1 x # 0x25 1 x # 1x25 1 x # 2x25 1 x # 3x25 875/1 TRI-WING® 25 mm 05066760001 1 x 1x25 05066762001 1 x 2x25 05066764001 1 x 3x25 857/1 Z Spanner 05057150001 05057151001 05057152001 05057153001 1 x 4x25 1 x 6x25 1 x 8x25 1 x 10x25 Handle/interchangeable blade system Manual and power tool operations Chuck-all Rapid-in and self-lock The handle/interchangeable blade system allows rapid exchange of the blades required for a wide range of applications. The sets come with a Kraftform handle, quick-release chuck and bits for manual and power tool operations. The Rapidaptor quick-release chucks hold ¼" DIN ISO 1173-C 6,3 and E 6,3 as well as Wera series 1 and 4 bits. The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_70_and_71_kk_71_security.html Wera - KK 71 Security 05057111001 - 4013288038661 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt 71 security, 32 pieces Kraftform Kompakt 70 and 71 Rapid-out Kraftform Prevents hand injuries Storage and transport Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The tools can be stored and carried either in a solid plastic case or a robust pouch. In this way the tool is always to hand. Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_70_and_71_kk_71_security.html Wera - KK 71 Security 05057111001 - 4013288038661 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057111001 价格&库存
很抱歉,暂时无法提供与“05057111001”相匹配的价格&库存,您可以联系我们找货
