05057460001
05057460001
    WERA(维拉)
    WERA - 05057460001 - Bit Set, BiTorsion, 52 Piece
05057460001 数据手册
Kraftform Kompakt 100, 52 pieces Innovations and Autumn/Winter Campaign 2017/2018 EAN: 4013288179968 Size: 155x105x55 mm Part number: 05057460001 Weight: 640 g Article number: Kraftform Kompakt 100 Country of origin: CZ Customs tariff number: 82079030 Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_100_kraftform_kompakt_100.html Wera - Kraftform Kompakt 100 05057460001 - 4013288179968 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt 100, 52 pieces Innovations and Autumn/Winter Campaign 2017/2018 Robust surface-protecting, compact, textile box Rapidaptor technology for rapid bit change BiTorsion bits in a length of 25 mm for long service life Impaktor bits in a length of 50 mm for particularly demanding jobs L-keys with Hex-Plus profile (prevents the rounding of hexagon socket screws) 52-piece; in surface-protecting, compact textile box which is extremely robust. Low volume and weight for simplified mobility. Compact tool set with 52 screwdriving tools. 1 bit holder Rapidaptor with quick-release chuck; 1 B bit holder Rapidaptor with quick-release chuck for take-up in the power screwdriver or use in the chuck of the power drill; 30 BiTorsion bits with a length of 25 mm for long service life, tough-absorbing (BTZ), for universal use, extra hard (BTH), 12 Impaktor bits with a length of 50 mm for particularly demanding jobs, 8 L-keys with Hex-Plus profile (prevents the rounding of socket head screws) and hexagonal ballpoint on the long arm for working at angles; textile box that is very robust and durable; can be positioned upright for tidy storage on the workshop shelf; additional surface protection thanks to the outer textile material. Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_100_kraftform_kompakt_100.html Wera - Kraftform Kompakt 100 05057460001 - 4013288179968 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt 100, 52 pieces Innovations and Autumn/Winter Campaign 2017/2018 Set contents: 813 R 05051272001 1 x 1/4x90 889/4/1 K 05052502001 1 x 1/4"x50 851/1 BTZ PH 05056420001 05056422001 05056424001 2 x PH 1x25 4 x PH 2x25 2 x PH 3x25 851/4 IMP DC 05057656001 05057657001 2 x PH 2x50 1 x PH 3x50 855/1 BTH PZ 05056710001 05056712001 05056714001 2 x PZ 1x25 4 x PZ 2x25 2 x PZ 3x25 855/4 IMP DC 05057661001 05057662001 2 x PZ 2x50 1 x PZ 3x50 867/1 TORX® BTZ 05066120001 2 x TX 10x25 05066122001 2 x TX 15x25 05066124001 3 x TX 20x25 05066126001 2 x TX 25x25 05066128001 2 x TX 30x25 05066130001 1 x TX 40x25 867/4 IMP DC 05057665001 05057666001 05057667001 1 x TX 25x50 1 x TX 30x50 1 x TX 40x50 800/1 BTZ 05056064001 05056066001 1 x 0.8x5.5x25 1 x 1.0x5.5x25 840/4 IMP DC 05057644001 05057645001 05057646001 1 x 4.0x50 1 x 5.0x50 1 x 6.0x50 950 PKS 051331500011) 05133151001 05133152001 05133153001 05133154001 05133155001 05133156001 05133157001 1 x 1.5x50 1 x 2.0x56 1 x 2.5x63 1 x 3.0x71 1 x 4.0x80 1 x 5.0x90 1 x 6.0x100 1 x 8.0x112 1) Regular hexagon Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_100_kraftform_kompakt_100.html Wera - Kraftform Kompakt 100 05057460001 - 4013288179968 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt 100, 52 pieces Innovations and Autumn/Winter Campaign 2017/2018 Impaktor Bits BTH- and BTZ-Bits “Take it easy” tool finder Rapidaptor holder Impact bits are needed when a strong power tool is used. Impact bits were specifically developed to withstand high power tool forces. BTH- (extra-hard) and BTZ- (tough) bits have an additional tempered BiTorsion zone, which reduces the hardness of the shaft by about 20 % in comparison to the drive tip.This means that the peak loads that cause bit breakage and premature wear are absorbed in this zone – something which enhances the service life of the bits. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. Rapid bit change without needing any additional tools. One-hand operation with a freely spinning sleeve for simplified guidance of the tool. Also available in a BiTorsion design. Chuck-all Surface protection Hex-Plus Textile boxes The Rapidaptor quick-release chucks hold ¼" DIN ISO 1173-C 6,3 and E 6,3 as well as Wera series 1 and 4 bits. Chrome-plated hexagon L-keys for outstanding surface protection and long service life. High corrosion protection. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! The textile boxes offer dramatically improved portability, and are spacesaving to boot! This means you can now carry the same collection of tools, in a much more compact and comfortable package. The hassle of running back and forth for the right tools has now become a thing of the past. And the much lower weight of a set makes carrying more convenient than ever before. The textile box including the tool will even survive a fall undamaged. Web link http://products.wera.de/en/kraftform_kompakt_kraftform_kompakt_100_kraftform_kompakt_100.html Wera - Kraftform Kompakt 100 05057460001 - 4013288179968 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057460001 价格&库存
很抱歉,暂时无法提供与“05057460001”相匹配的价格&库存,您可以联系我们找货
    • 1+967.26843
    库存:81
