05059291001
05059291001
    WERA(维拉)
05059291001 数据手册
Kraftform Kompakt VDE Torque 1.2 - 3.0 Nm, 15 pieces Kraftform Kompakt VDE EAN: 4013288168375 Size: 225x150x80 mm Part number: 05059291001 Weight: 760 g Article number: KK VDE 15 Torque 1,2-3,0 Country of origin: Nm extra slim 1 Customs tariff number: CZ 82054000 Kraftform Kompakt VDE torque screwdriver set with adjustable torque Adjustable Kraftform VDE torque holder exclusively for Wera VDE interchangeable blades VDE interchangeable blades 154 mm long In robust pouch 15-piece 15-piece torque VDE interchangeable blade set. Includes 14 blades (12 of which with a reduced diameter) with integrated insulation protection. Torque VDE holder with adjustable torque from 1.2-3.0 Nm. Kraftform Plus handle: hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_15_torque_1_2-3_0_nm_extra_slim_1.html Wera - KK VDE 15 Torque 1,2-3,0 Nm extra slim 1 05059291001 - 4013288168375 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE Torque 1.2 - 3.0 Nm, 15 pieces Kraftform Kompakt VDE Set contents: 7400 VDE 05074750001 1 x 7441 VDEx1.2-3.0 KK 65 iS PZ 05003455001 05003456001 1 x PZ 1x154 1 x PZ 2x154 KK 62 iS 05003413001 05003414001 1 x PH 1x154 1 x PH 2x154 KK 65 iS PZ/S 05003447001 05003448001 1 x # 1x154 1 x # 2x154 KK 67 i TORX® 05003431001 1 x TX 10x154 KK 67 iS TORX® 05003437001 1 x TX 15x154 05003438001 1 x TX 20x154 05003439001 1 x TX 25x154 KK 60 i 05003400001 KK 60 iS 05003406001 05003407001 05003408001 Kraftform VDE adjustable torque handle 1 x 0.4x2.5x154 1 x 0.6x3.5x154 1 x 0.8x4.0x154 1 x 1.0x5.5x154 Individually tested Handle/interchangeable blade system Kraftform VDE adjustable torque handle Each Kraftform Kompakt VDE set has been tested individually at 10,000 volts, in accordance with IEC 60900.This ten-times-higher testing load guarantees safe working at their maximum permitted load of 1,000 volts. The handle/interchangeable blade system allows rapid exchange of the blades required for a wide range of applications. Easy-to-read scale value. Measurement accuracy is ± 6 % in accordance with the standard EN ISO 6789. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_15_torque_1_2-3_0_nm_extra_slim_1.html Wera - KK VDE 15 Torque 1,2-3,0 Nm extra slim 1 05059291001 - 4013288168375 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE Torque 1.2 - 3.0 Nm, 15 pieces Kraftform Kompakt VDE Kraftform VDE adjustable torque handle Excess-load signal Inserting the blade Taking out the blade Simple setting of the required torque by hand. Distinctly audible and noticeable excess-load signal when the preset torque is reached. According to the job, the insulated inter-changeable blade with the required tipstyle, or a switch cabinet key is inserted into the clamping mechanism. By pulling and holding down the clamping sleeve the interchangeable screwdriver blade, or the switch cabinet key, is unlocked and can easily be taken out of the handle. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_15_torque_1_2-3_0_nm_extra_slim_1.html Wera - KK VDE 15 Torque 1,2-3,0 Nm extra slim 1 05059291001 - 4013288168375 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05059291001 价格&库存
很抱歉,暂时无法提供与“05059291001”相匹配的价格&库存,您可以联系我们找货
