851/4 BTH bits, PH 1 x 50 mm
Bits for Phillips Screws
EAN:
4013288034304
Size:
50x7x6 mm
Part number:
05059540001
Weight:
10 g
Article number:
851/4 BTH PH
Country of origin:
CZ
Customs tariff
number:
82079030
For Phillips screws
Particularly hard for semi-hard materials
BiTorsion zone to absorb peak loads
1/2" square socket drive
Take it easy tool finder: colour coding according to profile and size
BiTorsion bits for Phillips screws with elastic Torsion zone – where kinetic energy is diverted from peak loads – and softer BiTorsion zone to prevent
the bit tip from twisting under peak loads. This greatly extends the product service life; ¼” hexagon, suitable for holders as per DIN ISO 1173-F 6.3.
Web link
http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_phillips_screws_851_4_bth_ph.html
Wera - 851/4 BTH PH
05059540001 - 4013288034304
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
BiTorsion Bits
Two cushioning torsion zones
BiTorsion phase 1
BiTorsion phase 2
Peak forces that occur in power
tool applications often result in
premature wear of bits or damage
to the screw head. This usually
occurs during initial power-up and
the when the screw comes to a
standstill. Screwdriving could
become more productive and safer
if these peak loads could be
minimised. The Wera BiTorsion
system prevents premature wear.
The service life of the tool is
extended and the productivity of
power
tool
applications
significantly increased.
The effectiveness of the BiTorsion
system comes from a combination
of two shock-absorbing spring
elements. Both bits as well as
holders have a cushioning torsion
zone that diverts the kinetic energy
away from the drive tip during
peak loads.
The torsion spring integrated into
the unique BiTorsion holder
absorbs lower levels of peak loads
(Phase 1). Any overloading of this
spring is effectively prevented by
means
of
a
supporting
mechanism.
Higher peak loads are minimised
through the torsion effect of the bit
shaft (Phase 2). This effect is
achieved with a specific heat
treatment after the hardening
process of the bits. This reduces
the hardness of the shaft in
comparison to the drive tip.
Above-average service life
BiTorsion and conventional
tools
Prevents premature wear
“Take it easy” tool finder
Even the service life of
conventional bits is enhanced with
the use of the BiTorsion holder and
the BiTorsion bit also functions in a
normal holder.
The BiTorsion holder and the
BiTorsion bit can, of course, be
used independently of one
another.
The optimally coordinated features
of the torsion zones on the bit and
holder permit a phased yield when
under strain. The two-phase
Moreover, a long tool service life is
also ensured by the hardness of
the bits that matches the
respective application.
“Take it easy” tool finder with
colour coding according to profiles
and size stamp – for simple and
rapid accessing of the required
tool.
Web link
Wera - 851/4 BTH PH
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
Further versions in this product family:
mm
inch
05059540001
PH 1
50
2
05059542001
PH 2
50
2
05059544001
PH 3
50
2
Web link
Wera - 851/4 BTH PH
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05059540001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+26.691581+3.46910
- 5+24.952715+3.24310
- 10+22.4313610+2.91540
