5057416001
5057416001
    WERA(维拉)
    WERA - 5057416001 - BIT-CHECK SET W/UNIVERSAL HOLDER, 8PC
5057416001 数据手册
Bit-Check 7 Diamond 1, 7 pieces Bits assortment + Universal Bitholder EAN 4013288179999 Dimension: 72x65x12 mm Code: 05057416001 Weight: 71,8 g Country of origin: CZ Customs tariff no.: 82079030 Article-No. - Upright positionable Bit-Checks convince due to their functionality in a minimum of space BiTorsion bits for long service life Diamond coating for a secure fit in the screw, literally bites into the screwhead to prevent cam-out Rapidaptor holder for rapid bit change "Take it easy" Tool Finder: colour coding according to profile and size Bits with tiny diamond particles on the bit tip. This ensures a secure fit in the screw head, reduces the contact pressure required and lowers the risk of slipping. BiTorsion bits with an elastic torsion zone - where kinetic energy is diverted from peak loads - and softer BiTorsion zone to prevent the bit tip from twisting under high strain. This greatly extends the product service life. Comes with Rapidaptor technology, which allows bits to be attached without any need to actuate the sleeve. The removal of the bit is simple, just by pushing the sleeve forward - for rapid bit change with just one hand. For insertion in the power screwdriver or into the chuck of the power drill. The multi-component Bit-Check is convincing on account of its low weight and the maximum possible degree of compactness. In this respect, the soft material in the lower section of the Bit-Check ensures that the bits are securely held whilst being simple to remove at the same time. The profile and size of the bits are easy to recognise thanks to the Wera "Take it easy" Tool Finder with its colour coding and clearly visible imprint. Wera - Bit-Check 7 Diamond 1 05057416001 - 4013288179999 Stand: 28.09.2017
5057416001 价格&库存
很抱歉,暂时无法提供与“5057416001”相匹配的价格&库存,您可以联系我们找货
