950/13 HEX-PLUS IMPERIAL 1 SB
    WERA(维拉)
    WERA - 950/13 HEX-PLUS IMPERIAL 1 SB - L-Key Set, Hex-Plus Imperial, 13 Piece
950/13 HEX-PLUS IMPERIAL 1 SB 数据手册
950/13 Hex-Plus Imperial 1 SB L-key set, imperial, BlackLaser, 13 pieces Our Autumn/Winter production innovations EAN: 4013288221315 Size: 245x95x25 mm Part number: 05021721001 Weight: 529 g Article number: 950/13 Hex-Plus Imperial 1 Country of origin: SB Customs tariff number: CZ 82041100 13-piece set in a two-component clip Application:Hexagon socket screws Design:BlackLaser surface Tip:Hex-Plus, hexagonal ball tip at the long arm Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_our_autumn_winter_production_innovations_950_13_hex-plus_imperial_1_sb.html Wera - 950/13 Hex-Plus Imperial 1 SB 05021721001 - 4013288221315 Wera Werkzeuge GmbH 02.09.2021 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950/13 Hex-Plus Imperial 1 SB L-key set, imperial, BlackLaser, 13 pieces Our Autumn/Winter production innovations Set contents: 950 PKL inch 05022076001 05022073001 05022071001 05022068001 05022082001 05022080001 05022078001 05022074001 05022072001 05022070001 05022095001 050220810011) 050220790011) 1 x 3/16" x 160 mm 1 x 9/64" x 132 mm 1 x 7/64" x 119 mm 1 x 5/64" x 100 mm 1 x 5/16" x 200 mm 1 x 1/4" x 190 mm 1 x 7/32" x 180 mm 1 x 5/32" x 140 mm 1 x 1/8" x 126 mm 1 x 3/32" x 112 mm 1 x 3/8" x 212 mm 1 x 1/16" x 91 mm 1 x 0.05" x 83 mm 1) Regular hexagon L-Keys Hex-Plus Ball tip Size identification We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! The spherical drive profile means that it is possible to swivel the axis of the tool to that of the screw, and therefore enable angled, "around-the-corner" screwdriving jobs. The size of each L-keys has been engraved by a laser. In addition Take it easy L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_our_autumn_winter_production_innovations_950_13_hex-plus_imperial_1_sb.html Wera - 950/13 Hex-Plus Imperial 1 SB 05021721001 - 4013288221315 Wera Werkzeuge GmbH 02.09.2021 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950/13 Hex-Plus Imperial 1 SB L-key set, imperial, BlackLaser, 13 pieces Our Autumn/Winter production innovations Surface protection Secure hold and easy removal L-keys with BlackLaser surface treatment for outstanding surface protection and long service life. High corrosion protection. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_our_autumn_winter_production_innovations_950_13_hex-plus_imperial_1_sb.html Wera - 950/13 Hex-Plus Imperial 1 SB 05021721001 - 4013288221315 Wera Werkzeuge GmbH 02.09.2021 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
950/13 HEX-PLUS IMPERIAL 1 SB 价格&库存
很抱歉,暂时无法提供与“950/13 HEX-PLUS IMPERIAL 1 SB”相匹配的价格&库存,您可以联系我们找货
