967/9 TX XL MULTICOLOUR HF 1
    WERA(维拉)
    WERA - 967/9 TX XL MULTICOLOUR HF 1 - Key Set, Torx, L Key, Multicolour, Holding Function, Long, T8 ...
967/9 TX XL MULTICOLOUR HF 1 数据手册
967/9967/9 TX SXL Multicolour HF 1 L-key set with holding function, long TX XL Multicolour HF 1 L-key set with holding function, long, 9 pieces L-Keys for TORX® Screws EAN: 4013288193537 Size: 245x100x30 mm Part number: 05024470001 Weight: 358 g Article number: 967/9 TX XL Multicolour HF Country of origin: 1 Customs tariff number: CZ 82054000 L-keys for recessed TORX® screws Holding function for recessed TORX® screws Take it easy tool finder with colour coding according to sizes BlackLaser for high corrosion protection and long service life Wear-resistant clip material for enhanced durability High quality L-key set for recessed TORX® screws. Holding function: the wedging forces resulting from the contact pressure between the drive tip and the screw profile securely hold the screw on the tool. Featuring an extra-long arm. Partially with ballpoint: the ball-end on the long arm allows for reliable working even in difficult installation situations. L-keys with thermoplastic sleeve out of easy-to-grip circular material. The sleeve ensures that work is pleasant and easy on the fingers even at low temperatures. "Take it easy" Tool Finder with colour coding according to size. The BlackLaser surface treatment provides outstanding surface protection, even against corrosion, and a long service life. The tools are quickly to hand thanks to the laser-engraved and thereby wear-resistant size markings on the L-keys. Come in a practical clip fastener out of wear-resistant material, enabling secure storage of the L-keys as well as simple removal. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_967_9_tx_xl_multicolour_hf_1.html Wera - 967/9 TX XL Multicolour HF 1 05024470001 - 4013288193537 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 967/9967/9 TX SXL Multicolour HF 1 L-key set with holding function, long TX XL Multicolour HF 1 L-key set with holding function, long, 9 pieces L-Keys for TORX® Screws Set contents: 967 SXL HF TORX® Multicolour 05024471001 1 x TX 8x90 05024472001 1 x TX 9x101 05024473001 1 x TX 10x112 05024474001 1 x TX 15x123 05024475001 1 x TX 20x137 05024476001 1 x TX 25x154 05024477001 1 x TX 27x172 05024478001 1 x TX 30x195 05024479001 1 x TX 40x224 TORX® HF profile Surface protection Size identification Secure hold and easy removal In tight assembly or disassembly situations, for example in engine compartments, it is not possible to securely hold the screw with the hand on the screwdriver, and the screw subsequently often gets lost. Lengthy searches or the loss of the screw (with the associated danger that could bring about) are the consequence. The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that the screw is securely held on the tool! L-keys with BlackLaser surface treatment for outstanding surface protection and long service life. High corrosion protection. The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_967_9_tx_xl_multicolour_hf_1.html Wera - 967/9 TX XL Multicolour HF 1 05024470001 - 4013288193537 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
- 物料型号: 967/9 TX XL Multicolour HF 1 L-key set - 器件简介: 这是一套用于内六角螺丝的L型钥匙工具,具有保持功能,额外长的臂部,部分带有球头,可以可靠地在困难的安装情况下工作。 - 引脚分配: 包含9个不同尺寸的L型钥匙,尺寸从TX 8x90到TX 40x224。 - 参数特性: 具有保持功能,可以安全地固定螺丝;BlackLaser表面处理,提供出色的耐腐蚀保护和长寿命;激光雕刻的尺寸标识,便于快速识别和使用。 - 功能详解: 在狭窄的装配或拆卸情况下,例如在引擎舱内,使用该工具可以避免螺丝丢失或需要长时间寻找。 - 应用信息: 适用于需要在狭窄空间内操作内六角螺丝的场景。 - 封装信息: 工具套装包含在耐磨材料制成的实用夹子中,便于安全存储和简单取用。
967/9 TX XL MULTICOLOUR HF 1 价格&库存
很抱歉,暂时无法提供与“967/9 TX XL MULTICOLOUR HF 1”相匹配的价格&库存,您可以联系我们找货
