05003475001
05003475001
    WERA(维拉)
    WERA - 05003475001 - Screwdriver Set, Kraftform Kompakt, VDE 7 extra slim 1, 7 Pc
05003475001 数据手册
Kraftform Kompakt VDE 7 extra slim 1, 7 pieces News and Promotional Products Autumn/Winter 2020/2021 EAN: 4013288217691 Size: 190x100x50 mm Part number: 05003475001 Weight: 330 g Article number: Kraftform Kompakt VDE 7 extra slim 1 Country of origin: CZ Customs tariff number: 82054000 Individually tested VDE interchangeable blades with reduced blade diameters Multi-component VDE-insulated Kraftform handle with anti-roll feature Ergonomic Kraftform handle for low-fatigue working Individually tested tool as per IEC 60900 at 10,000V In robust folding bag with Wera 2go compatibility 6 VDE interchangeable blades with reduced blade diameter and integrated protective insulation, allows sunken screws and spring elements to be accessed and actuated. 1x 817 VDE Kraftform hand holder for ergonomic working. In a robust belt pouch. Individually tested tools as per IEC 60900. Individually tested via water quenching at 10,000 V for safe working at the approved voltage of 1,000 V. The bag is suitable for attachment to walls, shelves, workshop trolleys and the Wera 2go system thanks to the hook and loop fastener system on the back. Web link https://products.wera.de/en/tools_for_electricians_kraftform_kompakt_vde_kraftform_kompakt_vde_7_extra_slim_1.html Wera - Kraftform Kompakt VDE 7 extra slim 1 05003475001 - 4013288217691 Wera Werkzeuge GmbH 03.09.2020 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE 7 extra slim 1, 7 pieces News and Promotional Products Autumn/Winter 2020/2021 Set contents: 817 VDE 05003990001 1 x 9 x 102 mm KK 62 iS 05003413001 05003414001 KK 65 iS PZ/S 05003448001 1 x # 2 x 154 mm KK 67 iS TORX® 05003437001 1 x TX 15 x 154 mm 05003438001 1 x TX 20 x 154 mm KK 60 iS 05003406001 1 x 0.6 x 3.5 x 154 mm K70 11990176 1 x PH 1 x 154 mm 1 x PH 2 x 154 mm 1 x 70 x 50 mm Individually tested VDE-insulated screwdriver with reduced blade diameter Handle/interchangeable blade system Easy exchange Each Kraftform Kompakt VDE set has been tested individually at 10,000 volts, in accordance with IEC 60900.This ten-times-higher testing load guarantees safe working at their maximum permitted load of 1,000 volts. Reduced blade diameter with integrated protective insulation, allows sunken screws and spring elements to be accessed and actuated, individually tested as per IEC 60900. The handle/interchangeable blade system allows rapid exchange of the blades required for a wide range of applications. Kraftform Kompakt VDE sets come with an insulated handle and insulated inter-changeable blades, that can be exchanged without any special tools. Web link https://products.wera.de/en/tools_for_electricians_kraftform_kompakt_vde_kraftform_kompakt_vde_7_extra_slim_1.html Wera - Kraftform Kompakt VDE 7 extra slim 1 05003475001 - 4013288217691 Wera Werkzeuge GmbH 03.09.2020 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE 7 extra slim 1, 7 pieces News and Promotional Products Autumn/Winter 2020/2021 Belt pouch Multi-component handle Prevents hand injuries Kraftform The tools can be stored and carried in a robust belt pouch, keeping them always to hand. Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any "sticking" of the hand to the handle, making rapid repositioning of the hand possible. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. Web link https://products.wera.de/en/tools_for_electricians_kraftform_kompakt_vde_kraftform_kompakt_vde_7_extra_slim_1.html Wera - Kraftform Kompakt VDE 7 extra slim 1 05003475001 - 4013288217691 Wera Werkzeuge GmbH 03.09.2020 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05003475001 价格&库存
很抱歉,暂时无法提供与“05003475001”相匹配的价格&库存,您可以联系我们找货
