05073645001
05073645001
    WERA(维拉)
05073645001 数据手册
Bit-Check 10 Zyklop Mini 1, 10 pieces Zyklop Mini EAN: 4013288168115 Size: 125x80x25 mm Part number: 05073645001 Weight: 164 g Article number: Bit-Check 10 Zyklop Mini 1 Country of origin: Customs tariff number: CZ 82079030 1/4" Mini ratchet and tough viscous bits Ideal for working in confined spaces Tough viscous bits for universal use Use of 1/4" sockets also possible with the Wera adaptor 870/1 Take it easy tool finder: colour coding according to profile and size Many tools in a minimum of space. The sorting according to drive and size allows rapid accessing of the bits. The Wera Mini ratchet: drop-forged, fullsteel design. Fine-pitched mechanism with 60 teeth that allows a small return angle of only 6° for precise work. Simple left/right switchover. Ergonomically-designed ratchet head and lever. Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_bit-check_10_zyklop_mini_1.html Wera - Bit-Check 10 Zyklop Mini 1 05073645001 - 4013288168115 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 10 Zyklop Mini 1, 10 pieces Zyklop Mini Set contents: 8001 A 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 855/1 Z PZ 05072080001 05072082001 1 x PZ 1x25 1 x PZ 2x25 851/1 Z PH 05072070001 05072072001 1 x PH 1x25 1 x PH 2x25 867/1 TORX® 05066486001 05066487001 05066488001 1 x TX 15x25 1 x TX 20x25 1 x TX 25x25 840/1 Z Hex-Plus 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 Combines elegant design with incredible resilience. Suitable for rapid fastening even in confined working situations. The Wera Zyklop Mini is applied whenever fastening with a power tool or conventional tools is impossible due to insufficient space. The Zyklop Mini 1 for the direct attachment of bits; the Zyklop Mini 2 for the direct attachment of the special Wera Zyklop sockets. The Zyklop Mini Ratchets Small return angle Simple direction change For all applications. The fine tooth mechanism, with its 60 teeth, allows a small return angle of only 6° – ideal for precision work. Simple switching between left/right operations. difficult-to-access Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_bit-check_10_zyklop_mini_1.html Wera - Bit-Check 10 Zyklop Mini 1 05073645001 - 4013288168115 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 10 Zyklop Mini 1, 10 pieces Zyklop Mini Is rapid screwdriving possible with the Zyklop Mini? Slim design Is such a small tool sufficiently resilient? What parts can be connected to the Zyklop Mini 1? High working speeds can be attained with the Zyklop Mini. The thumb wheel is important, enabling more rapid screwdriving, and the Zyklop Mini hande only needs to be used for the final tightening of the screw. Its slim design makes it ideal for all particularly confined working situations. The Zyklop Mini 1 can withstand at least 65 Nm. That is far more power than can normally be transferred to such a small tool. Bits and sockets. Bits can be connected directly. However, a holder can be connected first and then the bit can be attached to this. This then serves as an extension with a free-turning sleeve. An adaptor e.g. Wera 870/1 is needed for sockets – ¼" hexagonal on a square drive (included in the Bit-Check and with the individual Zyklop Mini 1 in the set). Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_bit-check_10_zyklop_mini_1.html Wera - Bit-Check 10 Zyklop Mini 1 05073645001 - 4013288168115 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05073645001 价格&库存
很抱歉,暂时无法提供与“05073645001”相匹配的价格&库存,您可以联系我们找货
    • 1+420.69819
    库存:73
