7450 Kraftform ESD pre-set adjustable torque screwdrivers with Rapidaptor quickrelease chuck, 1/4 inch, 0,1 - 0,34 Nm
Series 7400 Kraftform Torque Screwdrivers
EAN:
4013288179210
Size:
170x40x40 mm
Part number:
05074820001
Weight:
122 g
Article number:
7400 vor ESD
Country of origin:
CZ
Customs tariff
number:
82054000
Pre-set Kraftform ESD torque screwdriver
ESD-safe tool thanks to surface resistance of < 10^9 Ohm
Multi-component Kraftform Micro handle for fast and ergonomic screwdriving
Suitable for bits with 1/4" hex head drive
Rapidaptor quick-release chuck for bits with 1/4" hex head drive
Wera torque screwdriver. Secure protection against electrostatic charge and associated damage. Comes with pre-set torque value for all applications
where the same, constant torque and repeat accuracy are required. The torque value can be modified within a specific measurement range.
Rapidaptor quick-release technology for rapid bit change. Unlimited torque to loosen seized screws. Multi-component Kraftform handle with hard and
soft zones for high working speeds, whilst being easy on the hand. Suitable for bits with ¼” hexagon head drive as per DIN ISO 1173-C 6.3 and E
6.3 (ISO 1173).
Web link
http://products.wera.de/en/torque_tools_series_7400_kraftform_torque_screwdrivers_pre-set_adjustable_torque_models_7400_vor_esd.html
Wera - 7400 vor ESD
05074820001 - 4013288179210
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Wera ESD Tools
High protection
Pre-set, adjustable Torque
Screwdrivers
Versatile
The requirements for ESD-safe
screwdrivers are specified in the
European standard DIN EN
61340-5-1. This standard also
includes a handle that has to be
out of a defined conductive
material. The Wera products in the
ESD series satisfy these standards
and the even more stringent
requirements demanded by some
technology companies.
The electric surface resistance of
the Wera ESD material is ≤ 10^9
ohm. This securely protects
components against electrostatic
energy and associated damage.
These tools are ideal for all
applications where a constant,
identical torque is required and
where a high degree of repeat
accuracy is needed. The torque
value can be adjusted within the
measuring range.
Rapidaptor technology makes the
tool adaptable since bits and
sockets can be exchanged rapidly.
Rapid-in and self-lock
Rapid-out
Chuck-all
Single-hand function
The bit can be pushed into the
adaptor without moving the sleeve.
The lock is activated automatically
as soon as the bit is applied to the
screw. Bits are held securely and
wobble-free.
Simply push the sleeve forward to
change the bit. The spring
mechanism lifts the bit off the
magnet and unlocks the tool. The
bit can be easily removed. The
rapid-out function makes it easy to
remove even the smallest bits
without extra tools.
The Rapidaptor quick-release
chucks hold ¼" DIN ISO 1173-C
6,3 and E 6,3 as well as Wera
series 1 and 4 bits.
Every function of the Rapidator
quick-release chuck, such as
inserting or releasing bits, can be
carried out with one hand. This is
faster, more economical and more
ergonomic. There are no
unnecessary manoeuvres.
Web link
Wera - 7400 vor ESD
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
Further versions in this product family:
art. no.
mm
inch
nm
nm
mm
inch
7450 ESD
89
1/4
0.1
0.1-0.34
133
5 1/4
05074820010
7450 ESD
89
1/4
0.1
0.1-0.34
133
5 1/4
05074822001
7451 ESD
89
1/4
0.3
0.3-1.0
133
5 1/4
05074822010
7451 ESD
89
1/4
0.3
0.3-1.0
133
5 1/4
05074824001
7452 ESD
89
1/4
0.9
0.9-1.5
133
5 1/4
05074824010
7452 ESD
89
1/4
0.9
0.9-1.5
133
5 1/4
05074840001
7460 ESD
105
1/4
0.3
0.3-1.2
155
6
05074840010
7460 ESD
105
1/4
0.3
0.3-1.2
133
6
05074842001
7461 ESD
105
1/4
1.2
1.2-3.0
155
6
7461 ESD
105
1/4
1.2
1.2-3.0
155
6
05074820001
1)
1)
1)
1)
1)
05074842010
1) Other pre-set values within the adjustable range can be delivered on request
Web link
Wera - 7400 vor ESD
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05074820001”相匹配的价格&库存,您可以联系我们找货
