167I 3K TX 8 X 80 MM
    WERA(维拉)
167I 3K TX 8 X 80 MM 数据手册
167 i VDE Insulated screwdriver for TORX® screws, TX 8 x 80 mm Kraftform Plus – Series 100 VDE EAN: 4013288108906 Size: 161x26x26 mm Part number: 05006184001 Weight: 29 g Article number: 167 i TORX® VDE Country of origin: CZ Customs tariff number: 82054000 Insulated VDE blades for secure work at 1,000 volts Smooth hard zones for high speed turning, soft grip zones for high torque transfer Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Zinc phosphate plated Wera VDE screwdrivers with multi-component Kraftform Plus handle for fast and low-fatigue working: hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. Individually tested in water bath at 10,000 volts for secure work at the permissible voltage of 1,000 volts. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_167_i_torx_vde.html Wera - 167 i TORX® VDE 05006184001 - 4013288108906 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 167 i VDE Insulated screwdriver for TORX® screws, TX 8 x 80 mm Kraftform Plus – Series 100 VDE Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. Individually tested Impact strength test Kraftform The individual testing at 10,000 volts, in accordance with IEC 60900, ensures safe working with loads up to 1,000 volts. Impact strength tested at −40°C, guaranteeing safety even under extreme conditions. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_167_i_torx_vde.html Wera - 167 i TORX® VDE 05006184001 - 4013288108906 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 167 i VDE Insulated screwdriver for TORX® screws, TX 8 x 80 mm Kraftform Plus – Series 100 VDE Multicomponent Kraftform handle Prevents hand injuries Rapid hand repositioning “Take it easy” Toolfinder Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any “sticking” of the hand to the handle, making rapid repositioning of the hand possible. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin “sticking” to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. Further versions in this product family: mm mm inch 05006181001 TX 5 80 81 3 1/8 05006182001 TX 6 80 81 3 1/8 05006183001 TX 7 80 81 3 1/8 05006184001 TX 8 80 81 3 1/8 05006169001 TX 9 80 81 3 1/8 05006170001 TX 10 80 81 3 1/8 05006172001 TX 15 80 98 3 1/8 05006174001 TX 20 80 98 3 1/8 05006176001 TX 25 100 105 4 05006177001 TX 27 100 105 4 05006178001 TX 30 100 105 4 05006179001 TX 40 150 112 6 05006186001 TX 45 150 112 6 Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_167_i_torx_vde.html Wera - 167 i TORX® VDE 05006184001 - 4013288108906 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 167 i VDE Insulated screwdriver for TORX® screws, TX 8 x 80 mm Kraftform Plus – Series 100 VDE Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_167_i_torx_vde.html Wera - 167 i TORX® VDE 05006184001 - 4013288108906 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
167I 3K TX 8 X 80 MM 价格&库存
很抱歉,暂时无法提供与“167I 3K TX 8 X 80 MM”相匹配的价格&库存,您可以联系我们找货
