334SK/6
334SK/6
    WERA(维拉)
334SK/6 数据手册
334 SK/6 Rack screwdriver set Kraftform Plus Lasertip and rack, 6 pieces Kraftform Plus – Series 300 EAN: 4013288111418 Size: 285x210x55 mm Part number: 05007680001 Weight: 729 g Article number: 334 SK/6 Country of origin: CZ Customs tariff number: 82054000 Screwdriver for slotted and cross-recess screws, Phillips Smooth hard zones for high speed turning, soft grip zones for high torque transfer Take it easy tool finder: colour coding according to profile and size Hexagonal blade and bolster for higher torque transfer Lasertip tips for more secure fit in the screw head 6-piece screwdriver set with Kraftform Plus handle for pleasant, ergonomic working that makes blisters and calluses a thing of the past. Hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. The Lasertip tip literally bites into the head of the screw and thereby prevents any slipping. More torque can be transferred with the help of an open-end or ring spanner applied to the hexagonal blade and the integrated bolster. "Take it easy" Tool Finder: colour coding according to profile and size. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace. Including a practical rack for tidy storage of the screwdrivers. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_334_sk_6.html Wera - 334 SK/6 05007680001 - 4013288111418 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 334 SK/6 Rack screwdriver set Kraftform Plus Lasertip and rack, 6 pieces Kraftform Plus – Series 300 Set contents: 350 SK PH 05008751001 05008752001 Kraftform Plus screwdrivers – ergonomics you can grasp. They relieve the entire hand-arm system even when used intensively. Along with other technical and product advantages such as the Lasertip for a secure fit in the screw head, Kraftform screwdrivers are the ideal choice whenever manual screwdriving jobs are concerned. 334 SK 05007670001 05007671001 05007673001 05007674001 1 x PH 1x80 1 x PH 2x100 1 x 0.6x3.5x75 1 x 0.8x4.0x90 1 x 1.0x5.5x100 1 x 1.2x6.5x125 Lasertip prevents slipping out Lasertip Reduced contact pressure It happens time and time again that the tip slips out of the screw head when screwdriving, sometimes damaging valuable surfaces or even causing injury. The tips of the Wera Lasertip screwdrivers are microscopically roughened by means of a laser. This rough surface literally “bites” itself firmly into the screw head. Slipping out becomes a thing of the past. A precisely-focused laser creates a sharp-edged surface structure. This laser treatment results in an edge hardness of up to 1000 HV 0.3. Wera Lasertip “bites” itself into the screw head and prevents any slips out of the recess. It is available for screwdrivers for slotted, Phillips and Pozidriv screws. Wera Lasertip reduces the contact pressure required and enhances force transfer – meaning less screwdriving effort is required. Screwdriving becomes safer and easier. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_334_sk_6.html Wera - 334 SK/6 05007680001 - 4013288111418 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 334 SK/6 Rack screwdriver set Kraftform Plus Lasertip and rack, 6 pieces Kraftform Plus – Series 300 Hexagonal blade and bolster Kraftform Rapid hand repositioning “Take it easy” Toolfinder Hexagonal blade and bolster for higher torque transfer. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin “sticking” to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_334_sk_6.html Wera - 334 SK/6 05007680001 - 4013288111418 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
334SK/6 价格&库存
很抱歉,暂时无法提供与“334SK/6”相匹配的价格&库存,您可以联系我们找货
