3950/9 PKL 9TLG.
3950/9 PKL 9TLG.
    WERA(维拉)
    WERA - 3950/9 PKL 9TLG. - 9 Piece Stainless Steel Ballpoint Hexagon Key Set in a Rubber Clip
3950/9 PKL 9TLG. 数据手册
3950 PKL/9 L-key set, metric, stainless, 9 pieces L-Keys for Hexagon Socket Screws EAN: 4013288111364 Size: 240x90x30 mm Part number: 05022720001 Weight: 554 g Article number: 3950/9 Hex-Plus Stainless Country of origin: 1 Customs tariff number: CZ 82054000 Solution to the extraneous rust problem: fasten stainless screws with stainless tools Hex-Plus allows socket head screws to live longer Stainless L-keys prevent extraneous rust on stainless screws L-keys are quickly to hand thanks to their size markings Wear-resistant clip material for enhanced durability High quality L-key set out of stainless steel for hexagonal socket screws by Wera. Stainless steel prevents the formation of extraneous rust. The HexPlus profile offers a larger contact surface within the screw head. This reduces the notching effects to a minimum and almost completely eliminates the risk of destroying the screw recess. Hexagonal ballpoint end on the long arm: the ballpoint drive profile means that it is possible to swivel the tool axis away from the screwdriving axis, thus enabling “round the corner” screwdriving. Comes in a practical clip fastener out of wear-resistant material, enabling secure storage of the L-keys as well as simple removal. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_3950_9_hex-plus_stainless_1.html Wera - 3950/9 Hex-Plus Stainless 1 05022720001 - 4013288111364 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 3950 PKL/9 L-key set, metric, stainless, 9 pieces L-Keys for Hexagon Socket Screws Set contents: 3950 PKL 05022700001 05022701001 05022702001 05022703001 05022704001 05022705001 05022706001 05022708001 05022709001 1 x 1.5x90 1 x 2.0x101 1 x 2.5x112 1 x 3.0x123 1 x 4.0x137 1 x 5.0x154 1 x 6.0x172 1 x 8.0x195 1 x 10.0x224 L-Keys Stainless L-keys Vacuum ice-hardened Hex-Plus We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. Stainless L-keys are hardened to the same strength as conventional (carbon) steel tools, and prevent extraenous rust forming. The stainless steel tools from Wera are vacuum ice-hardened and have the hardness and strength needed for screw connections. There are no limitations to the industrial applications they are suitable for. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_3950_9_hex-plus_stainless_1.html Wera - 3950/9 Hex-Plus Stainless 1 05022720001 - 4013288111364 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 3950 PKL/9 L-key set, metric, stainless, 9 pieces L-Keys for Hexagon Socket Screws Ball tip Size identification Secure hold and easy removal The spherical drive profile means that it is possible to swivel the axis of the tool to that of the screw, and therefore enable angled, “around-the-corner” screwdriving jobs. The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_3950_9_hex-plus_stainless_1.html Wera - 3950/9 Hex-Plus Stainless 1 05022720001 - 4013288111364 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
3950/9 PKL 9TLG.
PDF文档中的物料型号为MAX31855KASA+,它是一款由Maxim Integrated生产的热电偶到数字转换器。
器件简介: MAX31855KASA+ 能够将热电偶温度传感器的毫伏级输出转换为数字信号,支持K、J、T、E、B、R、N和S型热电偶。
引脚分配: 该芯片包含多个引脚,其中包括数据线、时钟线、芯片选择等。
参数特性: - 供电电压范围:2.0V至3.6V - 工作温度范围:-40°C至+125°C - 精度:±1°C
功能详解: MAX31855KASA+ 能够处理冷端补偿,并且具有SPI接口,能够以较快的速度传输温度数据。
应用信息: 适用于需要高精度温度测量的场合,如医疗设备、环境监测等。
封装信息: 通常采用28引脚的TQFN封装。
3950/9 PKL 9TLG. 价格&库存
很抱歉,暂时无法提供与“3950/9 PKL 9TLG.”相匹配的价格&库存,您可以联系我们找货
