6003 JOKER 22 SET 1
6003 JOKER 22 SET 1
    WERA(维拉)
    WERA - 6003 JOKER 22 SET 1 - Spanner Set, Combination, Ring, 22 Pieces
6003 JOKER 22 SET 1 数据手册
6003 Joker 22 Set 1 ring spanner set, 22 pieces Our Autumn/Winter production innovations EAN: 4013288221087 Size: 383x138x53 mm Part number: 05020232001 Weight: 3700 g Article number: 6003 Joker 22 Set 1 Country of origin: CZ Customs tariff number: 82041100 22-piece ring spanner set - particularly suitable for narrow installation spaces The special mouth geometry expands the placement possibilities of the tool The low return angle in the mouth "takes" the screw every 15° Slim ring side angled by 15° As the installation space becomes increasingly tight during screwdriving, tools are necessary that enable users to work successfully even in such situations. Narrow spaces require additional placement points of the tool. Can spanners be modified so that the placement possibilities of the tool increase? The combination of the 7.5° pivoted mouth and the double hexagon geometry doubles the placement points. A repeated 180° turn of the wrench around the longitudinal axis during screwdriving provides four placement possibilities, and bolts or screw heads can be engaged every 15°. The Joker 6003 with its smart mouth geometry significantly expands the range of uses in confined spaces. The Joker 6003 will automatically find the respective placement point after every turn. The slim yet robust ring side is angled by 15° to the tool axis. The high-quality surface treatment achieves a high and long-lasting corrosion protection. With tool finder Take it easy: colour coding by size. Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_our_autumn_winter_production_innovations_6003_joker_22_set_1.html Wera - 6003 Joker 22 Set 1 05020232001 - 4013288221087 Wera Werkzeuge GmbH 02.09.2021 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 6003 Joker 22 Set 1 ring spanner set, 22 pieces Our Autumn/Winter production innovations Set contents: 6003 Joker 05020190001 05020198001 05020199001 05020200001 05020219001 05020201001 05020202001 05020203001 05020204001 05020205001 05020206001 05020207001 05020208001 05020209001 05020210001 05020500001 05020501001 05020502001 05020503001 05020504001 05020505001 05020506001 1 x 5.5 x 105 mm 1 x 6 x 105 mm 1 x 7 x 110 mm 1 x 8 x 115 mm 1 x 9 x 120 mm 1 x 10 x 125 mm 1 x 11 x 135 mm 1 x 12 x 148 mm 1 x 13 x 160 mm 1 x 14 x 167 mm 1 x 15 x 174 mm 1 x 16 x 182 mm 1 x 17 x 190 mm 1 x 18 x 210 mm 1 x 19 x 230 mm 1 x 20 x 230 mm 1 x 21 x 260 mm 1 x 22 x 260 mm 1 x 24 x 280 mm 1 x 27 x 300 mm 1 x 30 x 330 mm 1 x 32 x 360 mm For very tight spaces Joker 6003: For pivoting angles under 30° Double-hex geometry The Joker 6003 ring spanner with its special mouth geometry – mouth side pivoted by 7.5° and the double hexagon profile – doubles the placement possibilities when repeatedly turning the wrench 180° around the longitudinal axis. Bolts and screw heads can be "accessed" every 15°. The Joker 6003 will automatically find the respective placement point after every turn. Thanks to the mouth side pivoted by 7.5°, double hexagon geometry and an adjusted application method (placement – screwdriving – turning – replacement – screwdriving – turning, etc), even screwdriving challenges allowing a pivoting angle of less than 30° can be solved. The double hexagon geometry on the mouth and ring sides secures the positive connection with the screw head or bolt and reduces the risk of slipping. Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_our_autumn_winter_production_innovations_6003_joker_22_set_1.html Wera - 6003 Joker 22 Set 1 05020232001 - 4013288221087 Wera Werkzeuge GmbH 02.09.2021 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 6003 Joker 22 Set 1 ring spanner set, 22 pieces Our Autumn/Winter production innovations Joker 6003: Angled ring side “Take it easy” tool finder The ring side is angled at 15° to the tool axis to prevent injury. Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). Web link https://products.wera.de/en/news_and_promotional_products_autumn_winter_2021_2022_our_autumn_winter_production_innovations_6003_joker_22_set_1.html Wera - 6003 Joker 22 Set 1 05020232001 - 4013288221087 Wera Werkzeuge GmbH 02.09.2021 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
6003 JOKER 22 SET 1 价格&库存
很抱歉,暂时无法提供与“6003 JOKER 22 SET 1”相匹配的价格&库存,您可以联系我们找货
