05057424001
05057424001
    WERA(维拉)
    WERA - 05057424001 - Bit Set, Universal Holder, Bit Check, Pozidrive, Phillips, Torx, Hex, 13 Piece
05057424001 数据手册
Bit-Check 12 Metal 1, 12 pieces Bit-Checks Metal EAN: 4013288179883 Size: 70x65x20 mm Part number: 05057424001 Weight: 105 g Article number: Bit-Check 12 Metal 1 Country of origin: CZ Customs tariff number: 82079030 Upright positionable Bit-Checks convince due to their functionality in a minimum of space Particularly for metal applications Tough viscous bits for universal use Universal holder with stainless sleeve Robust Bit-Check by Wera. Bit-Checks provide a quick overview of the tools available. Bits not needed are simply reinserted into the set and do not get lost. Simple transportation e.g. in the shirt pocket. Includes universal holder with strong permanent magnet for the take-up of bits with ¼” hexagon head drive. Can be inserted in the power screwdriver or for use in the chuck of the electric drill. Multi-component Bit-Check that can be positioned upright for permanently secure bit storage. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_metal_bit-check_12_metal_1.html Wera - Bit-Check 12 Metal 1 05057424001 - 4013288179883 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 12 Metal 1, 12 pieces Bit-Checks Metal Set contents: 899/4/1 05053457001 1 x 899/4/1 Kx1/4"x50 855/1 Z PZ 05072080001 05072082001 1 x PZ 1x25 1 x PZ 2x25 851/1 Z PH 05072070001 05072072001 1 x PH 1x25 1 x PH 2x25 867/1 TORX® 05066486001 05066487001 05066488001 05066490001 1 x TX 15x25 1 x TX 20x25 1 x TX 25x25 1 x TX 30x25 840/1 Z Hex-Plus 05056315001 1 x 3.0x25 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 At the workplace Universal holder with stainless steel sleeve Bit Ranges The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. The retaining ring and the strong permanent magnet ensure a particularly secure fitting of the bit in the holder. We have had bit ranges in our programme for many years now. In 2016, we put a question mark against everything and came up with a game changer. We wanted bit ranges with bits whose profiles and sizes could be more easily recognised. We wanted bit ranges that were as compact as possible and which were Wera-like at a first glance. We wanted bit ranges with bits that could be removed and reinserted more easily. We wanted bit ranges with as little weight as possible. The new multicomponent Bit-Checks satisfy these requirements; the soft material in the lower section of the Bit-Checks ensures that the bits are firmly held yet easy to remove. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_metal_bit-check_12_metal_1.html Wera - Bit-Check 12 Metal 1 05057424001 - 4013288179883 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057424001 价格&库存
很抱歉,暂时无法提供与“05057424001”相匹配的价格&库存,您可以联系我们找货
