05134021001
05134021001
    WERA(维拉)
    WERA - 05134021001 - Hex Bit Set, Patio Construction, 21 Piece
05134021001 数据手册
Patio construction set T 1, 21 pieces Tool sets for wood applications EAN: 4013288219510 Size: 140x115x55 mm Part number: 05134021001 Weight: 340 g Article number: Terrassenbau-Set T 1 Country of origin: CZ Customs tariff number: 82079030 High-quality 17-piece tool set for evenly flush countersunk screw heads for decking in patio construction Bit holder with adjustable screw depth limitation and protective felt ring for surface protection 15 bits (TORX®, PH, PZ) made from stainless steel to prevent extraneous rust plus 3888/4/1 K Rapidaptor stainless steel bit holder Take it easy tool finder: colour coding according to profile and size Compact folding bag with Wera 2go compatibility incl. 4 spare felt rings Compact Wera tool set with the 17 most common screwdriving tools for patio construction. Bits in stainless steel design prevent extraneous rust. With extra smart bit holder, which enables a uniform depth thanks to the variable screw depth limitation, and prevents damage to decking with the fitted felt ring. Web link https://products.wera.de/en/tools_by_trade_tool_sets_for_wood_applications_terrassenbau-set_t_1.html Wera - Terrassenbau-Set T 1 05134021001 - 4013288219510 Wera Werkzeuge GmbH 01.03.2021 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Patio construction set T 1, 21 pieces Tool sets for wood applications Set contents: 3888/4/1 K 05071100001 1 x 1/4" x 50 mm 3855/1 TS PZ 05071020001 05071021001 05071022001 1 x PZ 1 x 25 mm 2 x PZ 2 x 25 mm 1 x PZ 3 x 25 mm Bit holder for evenly countersunk screws in construction flush patio 3851/1 TS PH 05071010001 05071011001 05071012001 1 x PH 1 x 25 mm 1 x PH 2 x 25 mm 1 x PH 3 x 25 mm 3867/1 TS TORX® 05071032001 1 x TX 10 x 25 mm 05071033001 1 x TX 15 x 25 mm 05071034001 1 x TX 20 x 25 mm 05071035001 1 x TX 25 x 25 mm 05071037001 1 x TX 30 x 25 mm 05071038001 1 x TX 40 x 25 mm Evenly flush countersinking of screws Avoids damage caused by rot Individual screw depth The 881/4/1 bit holder allows for evenly flush countersinking of screws in decking when building patios. The screw depth can be adjusted as required. This prevents screws from being countersunk too deep. The screw head is evenly flush with the decking, therefore socalled "water nests", which usually lead to rot, are avoided. The required screw depth is set using the counter thread. Web link https://products.wera.de/en/tools_by_trade_tool_sets_for_wood_applications_terrassenbau-set_t_1.html Wera - Terrassenbau-Set T 1 05134021001 - 4013288219510 Wera Werkzeuge GmbH 01.03.2021 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Patio construction set T 1, 21 pieces Tool sets for wood applications Bit mounting with retaining ring Surface protection Stainless Steel Bits “Take it easy” tool finder Proven holder design, optimal fitting of the tool in the holder. Particularly robust for series applications. The exchangeable felt ring in the front of the bit mounting prevents brush marks on patio decking. Wera stainless steel bits are manufactured out of stainless steel so unsightly rust can be avoided. The stainless steel bits from Wera are vacuum ice-hardened and have the hardness and strength needed for screw connections. There are no limitations to the industrial applications they are suitable for. "Take it easy" tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. Web link https://products.wera.de/en/tools_by_trade_tool_sets_for_wood_applications_terrassenbau-set_t_1.html Wera - Terrassenbau-Set T 1 05134021001 - 4013288219510 Wera Werkzeuge GmbH 01.03.2021 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05134021001 价格&库存
很抱歉,暂时无法提供与“05134021001”相匹配的价格&库存,您可以联系我们找货
    • 1+928.795421+120.19810
    • 3+870.816653+112.69490
    • 5+783.673865+101.41750
