3160 I/7
3160 I/7
    WERA(维拉)
    3160 I/7
3160 I/7 数据手册
3160 i/7 Screwdriver set, stainless and rack, 7 pieces Series Kraftform Screwdrivers Stainless Steel VDE EAN: 4013288118073 Size: 285x210x55 mm Part number: 05022728001 Weight: 662 g Article number: 3160 i/7 Rack Country of origin: CZ Customs tariff number: 82054000 Insulated VDE blades for secure work at 1,000 volts Multi-component Kraftform handle for high working speeds and ergonomic screwdriving Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Lasertip tip, stainless to prevent extraneous rust High quality Kraftform Plus VDE screwdriver set out of stainless steel by Wera. The stainless tools from Wera are vacuum ice-hardened and have the hardness and strength needed for screw connections. They can be used for industrial application without hesitation. The individual testing of the Kraftform Stainless VDE screwdrivers in a water bath at 10,000 volts as per DIN EN 60900 (IEC 60900) ensures safe working with voltages of up to 1,000 volts. Secure working is also ensured under extreme conditions and verified with the proven cold impact resistance at -40° C. Mainly with Lasertip: the Lasertip tip literally bites into the screw head and prevents any slipping out of the screw recess. Multi-component Kraftform handle for fast and low-fatigue working. "Take it easy" Tool Finder: colour coding according to profile and size. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace. Includes a practical rack for tidy storage of the screwdrivers. Web link http://products.wera.de/en/vde_tools_series_kraftform_screwdrivers_stainless_steel_vde_3160_i_7_rack.html Wera - 3160 i/7 Rack 05022728001 - 4013288118073 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 3160 i/7 Screwdriver set, stainless and rack, 7 pieces Series Kraftform Screwdrivers Stainless Steel VDE Set contents: 3247 05208739001 1 x 0.5x3.0x70 3160 i VDE 050227290011) 05022730001 05022731001 05022732001 1 x 0.5x3.0x80 1 x 0.6x3.5x100 1 x 0.8x4.0x100 1 x 1.0x5.5x125 3162 i VDE 05022734001 05022733001 1 x PH 2x100 1 x PH 1x80 1) without Lasertip Why are stainless elements so often affected by rust? One reason: screwdriving jobs are often carried out with a tool out of made from conventional steel which can result in extraneous rust forming. This is annoying. We were confident that this could be prevented by using tools likewise out of stainless steel and meeting the required standard of industrial hardness. A tool series out of stainless steel. The forming of extraneous rust is prevented and a special vacuum ice-hardening process ensures the required degree of hardness – and they are even VDE-tested, too. Individually tested Wera Stainless Steel Tools. Vacuum ice-hardened The individual testing at 10,000 volts, in accordance with IEC 60900, ensures safe working with loads up to 1,000 volts. Solution to the rust problem: screw stainless steel together with stainless steel! Wera stainless steel tools are manufactured out of stainless steel so unsightly rust can be avoided. The stainless steel tools from Wera are vacuum ice-hardened and have the hardness and strength needed for screw connections. There are no limitations to the industrial applications they are suitable for. Web link http://products.wera.de/en/vde_tools_series_kraftform_screwdrivers_stainless_steel_vde_3160_i_7_rack.html Wera - 3160 i/7 Rack 05022728001 - 4013288118073 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 3160 i/7 Screwdriver set, stainless and rack, 7 pieces Series Kraftform Screwdrivers Stainless Steel VDE Lasertip Reduced contact pressure “Take it easy” Toolfinder Non-roll feature A precisely-focused laser creates a sharp-edged surface structure. This laser treatment results in an edge hardness of up to 1000 HV 0.3. Wera Lasertip “bites” itself into the screw head and prevents any slips out of the recess. It is available for screwdrivers for slotted, Phillips and Pozidriv screws. Wera Lasertip reduces the contact pressure required and enhances force transfer – meaning less screwdriving effort is required. Screwdriving becomes safer and easier. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. The hexagonal non-roll feature prevents any rolling away at the workplace. Web link http://products.wera.de/en/vde_tools_series_kraftform_screwdrivers_stainless_steel_vde_3160_i_7_rack.html Wera - 3160 i/7 Rack 05022728001 - 4013288118073 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
3160 I/7 价格&库存
很抱歉,暂时无法提供与“3160 I/7”相匹配的价格&库存,您可以联系我们找货
