05004047001
05004047001
    WERA(维拉)
    WERA - 05004047001 - METAL-PUSH RATCHET & SOCKET SET, 30PC
05004047001 数据手册
8100 SB 7 Zyklop Metal Ratchet Set with push-through square, 3/8" drive, metric , 29 pieces The Zyklop Ratchets, 3/8" EAN: 4013288173867 Size: 265x120x55 mm Part number: 05004047001 Weight: 1536 g Article number: 8100 SB 7 Country of origin: CZ Customs tariff number: 82041100 Extremely slim ratchet with long lever Return angle of only 4.7° Very robust without any restrictions on torque Absolutely smooth switchover of the non-detachable push-through square Take it easy tool finder with colour coding according to sizes Incredibly compact set arrangement with many tools in a minimum of space. A completely new ratchet set feeling thanks to the unique textile boxes that are very robust and durable. They can be positioned upright for tidy storage on the workshop shelf. Additional surface protection due to textile outer material. Low weight and volume for simpler mobility. "Take it easy" Tool Finder with colour coding according to sizes. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_7.html Wera - 8100 SB 7 05004047001 - 4013288173867 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 7 Zyklop Metal Ratchet Set with push-through square, 3/8" drive, metric , 29 pieces The Zyklop Ratchets, 3/8" Set contents: 8003 B 05004033001 1 x 3/8"x222.0 8794 LB 05003583001 1 x 3/8"x200.0 8784 B1 05003590001 1 x 1/4"x3/8"x44.0 855/1 Z PZ 05072080001 05072082001 1 x PZ 1x25 1 x PZ 2x25 8790 HMB 05003553001 05003555001 05003557001 05003558001 05003560001 05003561001 05003562001 05003563001 05003564001 1 x 8.0x29.0 1 x 10.0x29.0 1 x 12.0x29.0 1 x 13.0x29.0 1 x 15.0x29.0 1 x 16.0x30.0 1 x 17.0x30.0 1 x 18.0x30.0 1 x 19.0x30.0 8794 B 05003584001 1 x 3/8"x76.0 851/1 Z PH 05072070001 05072072001 05072074001 1 x PH 1x25 1 x PH 2x25 1 x PH 3x25 867/1 TORX® 05066486001 05066487001 05066488001 05066489001 05066490001 05066491001 1 x TX 15x25 1 x TX 20x25 1 x TX 25x25 1 x TX 27x25 1 x TX 30x25 1 x TX 40x25 840/1 Z Hex-Plus 05056315001 1 x 3.0x25 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 05056330001 1 x 6.0x25 05056335001 1 x 8.0x25 Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_7.html Wera - 8100 SB 7 05004047001 - 4013288173867 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 7 Zyklop Metal Ratchet Set with push-through square, 3/8" drive, metric , 29 pieces The Zyklop Ratchets, 3/8" Zyklop Metal Push The Zyklop Ratchet Metal Push Slim design Due to the ever-more confined working environment, space is becoming more and more an issue for the application of ratchets. Our product developers therefore intensively occupied themselves with the issue of confined working spaces, and Wera has now solved this problem. The extremely slim and robust Zyklop Metal ratchet with a long lever was what emerged. When the socket must not get lost and a coincidental change of direction has to be avoided at all cost, the Zyklop Metal Push is the correct choice. Extremely slim. Long leverage. With push-through square. Forged, full metal ratchet (chromemolybdenum) that is extremely robust with a long service life; slim design to enable work in very confined spaces. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_7.html Wera - 8100 SB 7 05004047001 - 4013288173867 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SB 7 Zyklop Metal Ratchet Set with push-through square, 3/8" drive, metric , 29 pieces The Zyklop Ratchets, 3/8" Square drive Dual ratchet teeth Ball lock Textile boxes Smooth push-through mechanism, that cannot get lost. The dual-ratchet-teeth design means that a 76 fine-toothing division can be achieved from the 38 robust teeth with a return angle of only 4.7°. The ball lock holds the sockets and attachments securely, ensuring safe working. A changeover into any predefined position is completed by simply pressing the release button – this is even the case in the 90° position. The textile boxes offer dramatically improved portability, and are spacesaving to boot! This means you can now carry the same collection of tools, in a much more compact and comfortable package. The hassle of running back and forth for the right tools has now become a thing of the past. And the much lower weight of a set makes carrying more convenient than ever before. The textile box including the tool will even survive a fall undamaged. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_ratchets_the_zyklop_ratchets_3_8_8100_sb_7.html Wera - 8100 SB 7 05004047001 - 4013288173867 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05004047001 价格&库存
很抱歉,暂时无法提供与“05004047001”相匹配的价格&库存,您可以联系我们找货
  • 1+1482.13895
库存:2
