05004202001
05004202001
    WERA(维拉)
    WERA - 05004202001 - Bit Set, Socket, 1/2" Drive, 9 Piece
05004202001 数据手册
8767 C TORX® HF 1 Zyklop bit socket set with 1/2" drive, with holding function, 9 pieces Zyklop Accessories, 1/2" EAN: 4013288184276 Size: 165x140x65 mm Part number: 05004202001 Weight: 1098 g Article number: 8767 C HF 1 Country of origin: CZ Customs tariff number: 82079030 Compact textile box with high robustness, low weight and volume Bit socket (non-impact) for manual or power tool operations The holding function holds screws securely on the tool Take it easy tool finder with colour coding according to sizes Knurling on lower socket end for more grip when used manually Bit socket set TORX®, with holding function for especially convenient screwdriving and a reduced risk of losing the screw when approaching the workpiece. Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_the_zyklop_ratchets_the_zyklop_ratchets_1_2_zyklop_accessories_1_2_8767_c_hf_1.html Wera - 8767 C HF 1 05004202001 - 4013288184276 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8767 C TORX® HF 1 Zyklop bit socket set with 1/2" drive, with holding function, 9 pieces Zyklop Accessories, 1/2" Set contents: 8767 C HF 05003830001 05003831001 05003832001 05003833001 05003834001 05003835001 05003836001 05003837001 05003838001 1 x TX 20x60.0 1 x TX 25x60.0 1 x TX 27x60.0 1 x TX 30x60.0 1 x TX 40x60.0 1 x TX 45x60.0 1 x TX 50x60.0 1 x TX 55x60.0 1 x TX 60x60.0 Zyklop Accessories Bit sockets with holding function for TORX® screws Take it easy tool finder system We did not just want our creativity to end with the ratchets themselves so we also occupied ourselves intensively with ratchet accessories. That is why our users are now provided with an extension with freely spinning sleeve and flexible lock to enable more secure and more rapid screwdriving. The sockets have been completely redesigned: we wanted to spare the user the need of having two different series – one for manual and the other for power tool applications. And: we wanted to enormous simplify the task of finding the right sizes. Technically, our own ambitious goals represented a real challenge: to endow sockets with the advantage of the holding function on screwdrivers and bits. We succeeded in this! The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that TORX® screws made according to Acument Intellectual Properties specifications are securely held on the tool! Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_the_zyklop_ratchets_the_zyklop_ratchets_1_2_zyklop_accessories_1_2_8767_c_hf_1.html Wera - 8767 C HF 1 05004202001 - 4013288184276 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8767 C TORX® HF 1 Zyklop bit socket set with 1/2" drive, with holding function, 9 pieces Zyklop Accessories, 1/2" Secure hold and easy removal Manual and machine sockets The all new smooth turning mechanism guarantees both secure and rattle-free storage, yet allows easy removal of the tool. The manual and machine sockets can be used both for hand and power tools use (non-impact). Users need just one socket set for all applications. Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_the_zyklop_ratchets_the_zyklop_ratchets_1_2_zyklop_accessories_1_2_8767_c_hf_1.html Wera - 8767 C HF 1 05004202001 - 4013288184276 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05004202001 价格&库存
很抱歉,暂时无法提供与“05004202001”相匹配的价格&库存,您可以联系我们找货
  • 1+941.33798
库存:4
