05017005001
05017005001
    WERA(维拉)
05017005001 数据手册
917 SPH Screwdriver for Phillips screws, PH 1 x 80 mm Kraftform Plus – Series 900 EAN: 4013288017734 Size: 178x33x33 mm Part number: 05017005001 Weight: 87 g Article number: 917 SPH Country of origin: CZ Customs tariff number: 82054000 Chiseldriver for fastening, chiselling and loosening Hexagonal blade extending through the handle Multi-component Kraftform handle for fast and ergonomic screwdriving Impact cap and bolster for the transfer of higher torque The Wera Black Point tip offers an exact fit and optimum corrosion protection Wera Chiseldriver for fastening, chiselling and loosening seized screws. Multi-component Kraftform handle for fast and low-fatigue working. Kraftform Plus: hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. A hexagon blade out of high quality bit material that extends right through the blade ensures full transfer of force, even when struck with a hammer. The ductile tempered material prevents the blade from splintering or breaking. Comes with an impact cap for durability and reduced risk of splintering. More torque can be transferred with the help of an open-end or ring spanner applied to the integrated hexagonal bolster. The Wera Black Point tip and a complex hardening process ensure a long service life of the tip, enhanced corrosion protection and an exact fit. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace and handle markings make for simplified finding and sorting of the tool. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_kraftform_plus__series_900_917_sph.html Wera - 917 SPH 05017005001 - 4013288017734 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 917 SPH Screwdriver for Phillips screws, PH 1 x 80 mm Kraftform Plus – Series 900 Integrated impact cap Pound-thru blade Integrated hex bolster Screwdrivers are often misused as chisels. This can be dangerous. The chiseldriver is the solution when not only screwdriving is required. For fastening, chiselling and loosening seized screws. Wera chiseldriver: the screwdriver whenever the going gets tough! An integrated impact cap lengthens the service life and reduces the danger of splintering. Nevertheless, always wear protective goggles. A hexagon blade made out of highquality bit material extends right through the handle – thereby ensuring full transfer of force, even when struck with a hammer. The ductile tempered material prevents the blade from splintering or breaking. Greater torque can be transferred by fitting an open-jaw or ring spanner over the integrated hex bolster. Wera Black Point tip Kraftform Prevents hand injuries Non-roll feature The Wera Black Point tip and a refined hardening process ensure long service life of the tip, improved corrosion protection and an exact fit. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The hexagonal non-roll feature prevents any rolling away at the workplace. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_kraftform_plus__series_900_917_sph.html Wera - 917 SPH 05017005001 - 4013288017734 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 917 SPH Screwdriver for Phillips screws, PH 1 x 80 mm Kraftform Plus – Series 900 Further versions in this product family: mm mm mm mm inch 05017005001 PH 1 5 8 80 98 3 1/8 05017010001 PH 2 6 10 100 105 4 05017015001 PH 3 8 13 150 112 6 05017020001 PH 4 10 16 200 117 8 Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_kraftform_plus__series_900_917_sph.html Wera - 917 SPH 05017005001 - 4013288017734 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05017005001 价格&库存
很抱歉,暂时无法提供与“05017005001”相匹配的价格&库存,您可以联系我们找货
    • 1+86.77851
    库存:17
