05030127001
05030127001
    WERA(维拉)
    WERA - 05030127001 - Screwdriver, Torx, T15, 80 mm Blade, 178 mm Overall - Screwdriver, Torx, T15, 8...
05030127001 数据手册
1567 TORX® BO Screwdriver for tamper-proof TORX® screws, TX 15 x 80 mm ESD Series EAN: 4013288039231 Size: 178x33x33 mm Part number: 05030127001 Weight: 56 g Article number: 1567 TORX® BO Country of origin: CZ Customs tariff number: 82054000 For TORX® socket screws with safety pin ESD-safe tool thanks to surface resistance of < 10^9 Ohm Multi-component Kraftform Micro handle with anti-roll feature and swivel cap For TORX® socket screws with safety pin The Wera Black Point tip offers an exact fit and optimum corrosion protection ESD-safe Micro screwdriver. Dependable protection against electrostatic energy and associated damage. TORX® BO screws have a protruding pin in their drive profile. This effectively prevents any unauthorised loosening since such screws cannot be actuated with “normal” TORX® tools. Only special TORX® BO tools have a corresponding bore hole for the take-up of the pin. Rapid twisting results from fixing the hand on the swivel cap and by rotating the fast-turning zone just below. This makes time-consuming grip adjustments unnecessary. Power zones with integrated soft sections ensure the transfer of high loosening and tightening torque; a precision zone provides for the right rotation angle during fine adjustment work. The Black Point tip offers optimised corrosion protection and an exact fit. Web link http://products.wera.de/en/screwdrivers_esd_series_1567_torx_bo.html Wera - 1567 TORX® BO 05030127001 - 4013288039231 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1567 TORX® BO Screwdriver for tamper-proof TORX® screws, TX 15 x 80 mm ESD Series When doing screwdriving jobs on electronic components (like e.g. smartphones and tablet PCs), there should be no electrostatic discharge as this could cause malfunctions and a complete failure. Therefore, tools that are secure against electrostatic discharge are indispensable. Wera ESD Tools High protection Wera Black Point tip The requirements for ESD-safe screwdrivers are specified in the European standard DIN EN 61340-5-1. This standard also includes a handle that has to be out of a defined conductive material. The Wera products in the ESD series satisfy these standards and the even more stringent requirements demanded by some technology companies. The electric surface resistance of the Wera ESD material is ≤ 10^9 ohm. This securely protects components against electrostatic energy and associated damage. The Wera Black Point tip and a refined hardening process ensure long service life of the tip, improved corrosion protection and an exact fit. Further versions in this product family: mm mm mm inch 05030131001 TX 10 80 81 4.0 3 1/8 05030127001 TX 15 80 98 4.0 3 1/8 05030128001 TX 20 100 98 4.5 4 05030129001 TX 25 100 98 5.0 4 05030130001 TX 30 115 98 6.0 4 9/16 Web link http://products.wera.de/en/screwdrivers_esd_series_1567_torx_bo.html Wera - 1567 TORX® BO 05030127001 - 4013288039231 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05030127001 价格&库存
很抱歉,暂时无法提供与“05030127001”相匹配的价格&库存,您可以联系我们找货
